Equal length TT exhaust manifolds?
Anybody here running them? I'm gonna be using Holset HX40 turbos. I don't mind having a pair of manifolds welded up but if somebody knows of a company that already built them, that would be great. I haven't had any luck searching Google so far.
those are some big turbos, probably have to go top mount and use the PTK style or upp sytle fender well mount.
not aware of anyone who has true equal length unless you go top mount. the ptk sytle could be made equal length but honestly on a turbo application I'm not sure it would gain much or be worth the $$ and hassle.
Lmao damn I just checked their website and they want wayyy too much money. I'm very familiar with designing a TT V8 system and IMO they're a rip off. Thank you for the advice though. I really didn't know the market for turbo exhaust manifolds was that horrible for the C5.
The hx40 are medium sized IMO. They would sit in front of the engine but not as close as the PTK setup I saw. My c5 has no AC and I'm removing the PS before the headers get built. Battery will be in the trunk and windshield res will be ditched. Also getting a different front bumper, one that will let in more air.
If I'm building turbo manifolds they might as well be equal length. There really isn't much to it. I could just buy those lame turbo manifolds from eBay for $150 and modify them a bit, but where's the fun in that.
I really dig the UPP top mount stuff and they have a c5 solution
I bought a c5 ttix setup which has proven to work really well but if you are concerned about 500 manifolds no offense you are either very talented or in the wrong wheel house.
the best way to get into a c5 tt is to buy them DONE Many have come on the market at bargain prices and even if you need to do a bit of work to them to get them up to spiff, you are paying pennies on the dollars for the mods
ya pays ya money and takes your chances. No offense and good luck. Fabbing up the manifolds with some nice u bends or those nice little stainless schedule L elbows is tedious work and takes some skill. The space is very tight.
I think Huron and UPP have some really nice setups with lots of options, but if you have the time and resources you can certainly make your own. You might be able to pick up some "base stuff" that you can modify as there are tons of LS generic kits.
Keep us posted and have at it!!
CK@UPPCOS (02-14-2017)
Former Vendor
I was obviously referring to PTK $3000 kit that DIDNT INCLUDE turbos or intercooler.. $500 isn't ****. I own a corvette, not a Honda. Your opinion is to just buy them, but I know better manifolds can be built for under $1000 and I don't care about shiny SS. Mild is steel will work just as good.
Call me a skeptic, but I have yet to be convinced of any real benifit for equal length turbo headers on anything less than all all out race engine.
To me, flow would be the more important factor; with the back pressures involved i think you would be hard pressed to see any scavenging effect. Which again to me, seems superfluous with boost.
Former Vendor
But it sounds impressive doesn't it? "Equal length"......
But a correct skeptic.
There are very few V8's that mere mortals will be driving where it is worth the effort of equal length, unless of course it is installed in a vehicle where it is very easy to do that.
Clearly a Vette is not one of those. Get over it. People have made enough power on cast truck logs to blow most engines to pieces.
beautiful work but I would keep the runners much shorter
nice street rod headers, but not a good turbo manifold
you want the turbo very close to the exh valve with as efficient a flow as possible those headers loose spool up efficiency compared to a manifold designed for turbos
look at what bmw and audi do with turbos and it will help illustrate the point a bit
That very much depends whether maximum power is your end goal, or fast spool/torque
If it is maximum power then equal length, tuned headers etc etc can still all offer benefits and also offer scope for a more aggressive cam to work better.
And lets face it, for the type of vehicle it looks a hell of a lot better than short manifolds would !
For spool I have heard that well designed headers are better than logs anyway. It's a bit like long tubes as you can use the exhaust energy better / stop stuff going back into the cylinder.
Former Vendor
Metallurgy 101 - the acceptable working temperatures of different alloys....
SS is far superior to mild, especially in terms of supporting the weight of the turbos and vibration under heated conditions. Not to mention heat/cool/repeat.
Mild<409<304<321
Mild<409<304<321
