I dont think any clarity has been given in this thread yet ? As to why they were even running 85psi ? That's just dumb as a base pressure.
That picture was the first tune. We have set the fuel pressure at 55psi and still having the issue with the pump running lean after it been running a long time. Either way the Walbro 450 still hasn't gone lean after a long time running.
well, i thought i would mention it. post #1 showed a pressure of 72 psi base and 85 psi max. i dont think that is anything extraordinary.
on the topic of "stupid high fp": when the fuel systems used to run 3 bars (or 2.5 bars) i would set up my cars to run at 4- 4.5 bars. the atomisation is better at these levels, keeping in mind that around 6 bars the injectors stopp working. so if you then run say 1.5 bars of boost you end up with 90 psi fp max. its not much different on a referenced ls1. and a pump upgrade yields around 65 psi at idle returnless anyway.
of course you need a pump supporting that and if you dont find one in the walbro catalog, dont despair, there are plenty of unexpensive pumps that will support 6-8 bars. i preferred to use bosch pumps for the ke-jetronic in audis. those systems ran 6 - 6.5 bars stock.
of course you need a pump supporting that and if you dont find one in the walbro catalog, dont despair, there are plenty of unexpensive pumps that will support 6-8 bars. i preferred to use bosch pumps for the ke-jetronic in audis. those systems ran 6-6.5 bars stock.
Part of the issue is you're using a pump where flow starts to drop off quite a bit around 75psi because of the internal pressure bypass. So a 75psi base is pretty much silly.
If you were using the Bosch pumps, then that is a different matter, but you were not using those ? And you cannot compare an ancient jetronic system to modern fuel injectors. They're just vastly different.
