Only hitting 20psi
Old Apr 8, 2017 | 06:02 PM
all4spl's Avatar
all4spl
Default Only hitting 20psi
So I have a 6.1 lq9 with 15% innovators west crank and 2.75 upper pulley. I have 243 heads stock with springs, Holley Hiram, and tick stage 2 blower cam. Also have 2" headers and 3" catback. I have a proefi ecu and had a zr1 map sensor which was maxed out at 23psi. (Proefi uses 4.5 volts where as gm uses 5 volts) I upgraded to a Holley 5 bar and now it's telling me I only make 20 psi. I put it on the Dyno to make sure that it was reading correct and the Dyno says 20 psi as well. I checked for boost leaks with the compressor and a block off and checked through the throttle body and into the manifold and it seemed good. Also check from blower up to throttle body with a block before throttle body and it seemed fine.
Any ideas?? Also have a&a bracket with the earlier hd tensioner with a 10 run setup. My engine shouldn't be moving that much air to only his 20psi.
Old Apr 13, 2017 | 12:39 AM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Could the MAP sensor calibration have been off in your tune file?
Old Apr 13, 2017 | 01:40 AM
ss4luck's Avatar
ss4luck
What sort of boost do you think you're supposed to be seeing? Is it making the power it supposed to?
Old Apr 13, 2017 | 03:22 AM
winters97gt's Avatar
winters97gt
Boost is pretty much irrelevant. Is the car making power and trapping well?
Old Apr 15, 2017 | 06:20 PM
c5mtl's Avatar
c5mtl
20 sounds about what it should be...u running a filter ? I made about 21 with a bellmouth .... u shouldn't get caught up with psi numbers.. I'd rather make 1000hp with 15 psi over 25 psi
Old Apr 17, 2017 | 05:40 AM
stevieturbo's Avatar
stevieturbo
Bizarre that any ecu would use anything other than a 5v reference. That is pretty much the world standard for sensor power supplies. Not even sure how some would behave if not fed with 5v.
And have you calibrated the ecu correctly for the sensor setup you are using ?
ie get a Mityvac or similar and test it.
And was the previous setup calibrated correctly in the same manner ? If not, you may not be comparing like for like, and actual boost may be the same before/after anyway.
To Only hitting 20psi
