ECS stage 1 fuel system
I put this kit in last summer and it has leaked from day 1. Just getting around to trying to fix it today but have a couple questions. Car is a 2002 Z06. It looked as though the fuel was leaking at the bottom of the bulkhead at the 5 o'clock position if facing the bulkhead with the system installed in the car. When the assembly was pulled out of the tank and bulkhead separated from the factory gasket it looked as though the factory gasket (where it flattens out) is almost too thin to bridge the two o-rings on the back of the bulkhead. Pic here:
I just don't see how this can make a good seal. It's leaking at the narrow part on the factory gasket where it meets the orings. Just wondering if installed this wrong or maybe even have the wrong kit for my car?
Emailed Doug, waiting to hear back but it's bugging me so I thought I would ask here as well.
Thanks guys🍻
Thanks guys🍻
Thanks for the reply smoken. I thought about that as well but there are little raised studs if you will where each of those long m5 screws land. I'm not sure the o rings in the bulkhead would make contact with the tank otherwise. And there's this part in the instructions where it says to leave the factory gasket installed.
That's a great question! I'll go outside and check in a few min. Thanks for that pic! Definitely going to shed some light on the situation.
I have the 3.75" block which looks to be correct for my year. I kinda wish that was the problem lol. Would have been an ez fix. This is my tank, not sure if every year looks like this but anyway.
Thanks for the help.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
It looks like you are double o-ring'ing it. The tank side gets the original gasket and the sending unit gets our o-ring seal.
I think that is your issue from looking at the pics you posted.
Smoken1 (04-10-2017)
The first picture appears to be the OEM gasket on the tank side of the ring but it looks worn to me. Have you tried replacing the OEM gasket? I personally had to massage one of the pipes in the fuel hat to keep the bucket from hitting the bottom of the tank. Until I straightened the pipe out a bit I couldn't get my fuel hat to sit flush, maybe this could be your problem as well.
Thanks for chiming in doug and purpoise 🍻. Yes it is definitely is double gasketted. Guess I figured I had them to put in and there were grooves there so I did it? I would have a had a couple left over if I didn't. Why even cut those grooves in the bulkhead if there's no orings there? The factory gasket doesn't look like it lines up to fit in them? Sorry if my questions seem ridiculous guys. Thanks for the help. And yes purpoise I had to bend mine as well, maybe I will try a bit more this time.
I'll have to check and see if they line up. Looking at it I don't see how that's possible being the gasket tapers in 2 spots. The grooves are not concentric the whole way around and the bulkhead grooves definitely are. I see from your pic that it doesn't really matter that they line up though. I guess the inner ring does fit despite what the outer is doing. Still looks like it would seal. Thanks smoken
Let me know if it all works out if you get to it b/4 I do
I have an extra new gasket if you can't find one local to you
Thanks brother I appreciate the offer. I don't want to put you out. I'm going to grab one at the dealer as I want to tackle this on the weekend. 🍻
Just wanted to post an update as I replaced the factory gasket and reinstalled the pump correctly (without the O-rings on the inside as well) Everything is as it should be, no leaks.
Thanks to all who responded
DOUG @ ECS (05-08-2017)
ECS is usually great but it's really pissing me off that this doesn't fit into place. If they know about this, it should be mentioned in the instructions.
