View Poll Results: Are all dyno numbers to be taken as truth?
Yes
0
0%
Dynos are just a tool for tuning and measuring deltas
21
91.30%
No
2
8.70%
My car is a dyno queen
0
0%
Multiple Choice Poll. Voters: 23. You may not vote on this poll
Dyno Education - Tips, Tricks, and False Records
We plan on participating in a few of those this year also. Mostly we're going to do 1/8th mile events though. But doing the cruise in a car that's hopefully going to scare a 4 do death in the 1/8th this year is going to be kinda rewarding.
BTW, we were 3300# raceweight when we ran that if it'll help you in any way setting up your car to run the number we did. Any other details you need and I'll gladly tell you our exact combo if interested. PM me.
Well I like all the info in this thread Ben! Good stuff. I used to really like my dyno numbers a while back for sure. But in the end its just another tuning tool. But no one wants to spend a lot of money effort, and time to see a lower dyno number than what they were expecting. But I've kind of moved on from them and use them just like a base line for either solving a problem or reaching a specific goal, what ever it is IE: Drag racing, half mile, Mile or what ever floats your boat. Hell I can't even find a complete pull from the last time I was on one tuning. Like at TI for instance, My car isn't the platform to win much other than go a few rounds because of the competition etc... But I like the event and set goals for myself such as making past a certain number of rounds, and a MPH goal. All of which SHOULD back up any data from a dyno etc... With that said it doesn't always happen. So my advice to anyone is to just keep trying!
I think this is directed towards me so here goes. 8" lower 3.2" supercharger pulley from 928 Motorsports with that special fancy anti-slip coating to keep the belt from slipping. 8 rib setup. We still had to remove the air filter and put on a screen as the extra work of having to pull that much air through the filter and tube made the belt slip above 6000 RPM. No N2O on the car. I posted the dyno sheet before and it's almost perfectly flat from 6000 RPM until it's shut down. The car stays between 6000-6800 RPM the whole pass from the hit of the throttle. That's a big part of why it ran like it did with only the meager horsepower output from the too small supercharger head unit.
Yup, dyno numbers are for the pub.
A fast car wins every time regardless of pub dyno numbers.
The only numbers that matter with a dyno, are the before/after whilst in a tuning session.
Although I do think the speed is on the high side for that power.....but then of course it also highlights that dyno numbers on their own cannot be trusted in that manner
So a car trapping 160 mph at Atco is faster than a car trapping 150 mph at Bandimere?
One thing I've noticed in the car scene is that people like to promote whatever their car/platform etc. is good at.
If you are a drag strip guy, street racers and roll racers are morons.
If you are a road racing guy, anyone who doesn't turn can't drive.
If you are a street race guy, you hate the NHRA and the rules they impose
Realistically there are a ton of different ways to enjoy a car, and the older I get, the less I care about what other people are doing. With the exception of Albert, most of the 8/9 second guys would be extremely butt hurt if they came to a track up here and got to experience 4000-6000 DA
I think some people might be pleased to post up their corrected timeslip at 4000 to 6000 DA. Especially if they corrected it for altitude 1st and then put it back through the calculator with the wrong barometric pressure entered. They might even be able to get some people to consider it as a new C5 record.
#33
I know for sure what crappy DA does for your performance potential. That's why we don't race a whole lot in July and August when the DA goes above 3000' here in the South. I truly don't want to go to 6000' DA and try it. I'm sure we'd be fortunate to run a low 9 and probably wouldn't go anywhere near 150 MPH.
#34
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
This only true if many variables are constant, which of course is not usually the case. I have jumped in several customers cars over the years, including auto's, and put 5+ MPH on their best pass simply because they did not have a bunch of seat time. Did the car make more power when I drove it? I don't think so. I have had many conversations over the years with people who were convinced that ET varies but MPH will be somewhat consistent between drivers, but I strongly disagree with that.
As for the tuning going leaner in lower gears, that is inherent with factory computers so there is no really good way of eliminating it without going to an aftermarket ECM. The factory computer will richen the mixture with increased load, or in this case lean the mixture out in lower gears due to less load. It is amplified once you are making 1000+ hp.
Coincidentally that is the exact reason why I sold my DynoJet and bought the DynoPack. A 1000 rwhp car would have a fast dyno pull like I'm sure you have all seen the video's of, and say a stock 2.73 auto 97 would take a minute to do the same pull.
Well what happens when those cars are released into the wild is the 1000 hp car is very rich and the stock auto is lean.
Oh and yes, dyno's are a tuning tool that can be manipulated, but that will come back to bite the operator sooner or later. I have found an auto making 700+- rwhp will dip into the 9's around 140ish, I use that as a bench mark typically.
romandian (04-27-2017)
#35
Heck, that was 12+ years ago! 680rwhp was so much back then!
#36
My current combo has never been on a dyno. All street and track tuned. I have no idea what she makes, I only care how fast she goes!
#37
how so?
#39
Most excellent!
#40
Lot's of good info in here. It's interesting that track performance shows up in a dyno thread. I'm all for it actually because you can't cheat the track as far as all out effort. There is no correction factor when you pull around to the time shack for your slip. The scoreboard doesn't show ET and MPH and then the correction factor that was used to obtain the numbers. I'm sure some people would appreciate it because then maybe their car would actually run what the shop's dynosheet claims.
Don't misunderstand me. I understand traction issues, or some mechanical errors happening during the run. However if the car makes a clean pass in every gear like the dyno sheet shows with no hiccups in power delivery, it should get close. A true 1400hp car should be able to fall out of bed and run an 8.99 on a fair pass.
