fuel pressure gauge ?
Old Sep 26, 2002 | 08:42 PM
QuickSilver2002's Avatar
QuickSilver2002
Default fuel pressure gauge ?
I was trying to install my autometer electronic fuel pressure gauge last night and it looks like you need some type of adapter to hook it up to the fuel rail.
Is this what you guys have done? Where did you get the adapter? Does it need to be an autometer part?
Old Sep 27, 2002 | 01:54 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: fuel pressure gauge ? (QuickSilver2002)
You need to attach it to the schreader (sp) valve. Then the sender unit clicks into adapter.
I would take a pic, but my batteries just went dead in the camera. Email me tomorrow if you need them.
Old Sep 27, 2002 | 11:23 AM
ganson's Avatar
ganson
Default Re: fuel pressure gauge ? (ICULUKN-C5)
I'm at the same point installing my electric fuel pressure gauge for the ATI kit. Pics of the adapter connection would be great.
Old Sep 27, 2002 | 11:47 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: fuel pressure gauge ? (ganson)
I will post tonight.... have to goto work..
Old Sep 27, 2002 | 11:57 AM
ganson's Avatar
ganson
Many thanks - looking forward to it. :yesnod:
Old Sep 27, 2002 | 11:59 AM
QuickSilver2002
I really don’t need pics. I just need to know where you can get the adapter. The sender has a male end and so does the fuel rail. Maybe I’m missing something that should have been in the box. .
[Modified by QuickSilver2002, 4:00 PM 9/27/2002]
Old Sep 27, 2002 | 12:06 PM
ganson's Avatar
ganson
Same deal with mine; they said it comes with adapters, but none were in the box.
Old Sep 27, 2002 | 02:21 PM
jeffh355's Avatar
jeffh355
Please post the pic's when you get time, thanx.
Old Sep 28, 2002 | 11:36 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: fuel pressure gauge ? (jeffh355)
You both have mail. Could one of you please post the pic here. I dont have a host yet
Old Sep 28, 2002 | 03:08 PM
ganson's Avatar
ganson
OK, I posted his fuel pressure adapter on my site at http://www.ganson.com/fuelpressure.htm
because I don't know how to post a pic on this forum.
Thanks very much for your pic, and could you tell us where to get the fuel rail adapter?
Old Sep 28, 2002 | 08:49 PM
ICULUKN-C5's Avatar
ICULUKN-C5
I think i got mine from Nitous express.
[Modified by ICULUKN-C5, 5:51 PM 9/28/2002]
Old Sep 29, 2002 | 05:22 PM
QuickSilver2002
It's rather confusing.
The Autometer instructions say to use part# 3275 to connect to a schreader valve fuel rail, but in looking at that part on the Autometer site it is male to male. http://www.autometer.com/hp/2001_cat...sories/87.html
Is the valve on the end also threaded on the inside?
Anyway, I guess I'll call one of the shops tomorrow to find out what they use.
[Modified by QuickSilver2002, 9:24 PM 9/29/2002]
Old Sep 29, 2002 | 07:01 PM
ganson's Avatar
ganson
I just got mine all hooked up and working using the fitting from a mechanical fuel pressure gauge and a female-to-female coupler. I went and bought the mechanical guage at Auto Zone out of desperation, and got the coupler at Home Depot.
Too bad I got the 0-15 PSI electrical gauge though. It just stays pegged while driving. I wonder if I can just change the gauge, and keep the control box?
Old Sep 29, 2002 | 07:14 PM
ganson's Avatar
ganson
#3280 looks more like the right one, assuming it has the pin in the center to open the valve in the fuel rail. That's what is on the end of the mechanical gauge I bought. You would also need the female-to-female coupler to attach the sensor to the #3280 part.
Old Sep 30, 2002 | 04:38 PM
QuickSilver2002
FYI, talked to Mike at xtreme. He said the schreader comes out pretty easy with a little tool that can be found at an autoparts store. That seems to be the trick.
Old Sep 30, 2002 | 04:50 PM
ganson's Avatar
ganson
I the schreader the little pin thing inside the end of the fuel rail?
Old Oct 1, 2002 | 01:26 AM
ICULUKN-C5's Avatar
ICULUKN-C5
I drilled mine out. It wasn't providing enough fuel for the solenoid.
To fuel pressure gauge ?
