Which pulley?
Old May 19, 2017 | 09:21 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default Which pulley?
Which pulley will put 10psi on my combo?
A@A P1sc kit, LS7 blade maf, LS7 tb, fast 92, stock 99 LS1 heads/cam and shortblock.
It goes to be tuned in a week. Time enough to order a different pulley if needed. 3.85" currently installed.
Old May 19, 2017 | 10:48 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I'm right at 10 psi with a 3.7. I'm running a p1 with a ECS big blower cam.
Old May 19, 2017 | 10:49 PM
Ls2gtoowner's Avatar
Ls2gtoowner
Not really a set answer every car/setup is different.
Old May 20, 2017 | 03:19 PM
Quickshift_C5's Avatar
Quickshift_C5
Agreed. Use of cams and other components will affect the boost.
For reference, I ran a 3.6 pulley for 10psi and am currently using the 3.4 pulley at 12psi. Car is an 01Z with a stock cube forged 346, oem heads, mild blower cam, and longtubes.
Old May 21, 2017 | 06:48 AM
winters97gt's Avatar
winters97gt
Apples to oranges. His step up ratio is 4.10 on his P1. Your blower 3.60.
P1 is rated at 1200cfm
SI is rated at 1150cfm
Can't just compare pulley size on different applications.
To Which pulley?
