Do you need just the spring from an adjustable/rebuildable actuator (TiAL, Forge, HKS, etc.) or do you really need a complete wastegate actuator for an internal wastegate style turbo?
If you need a complete wastegate actuator (and not just the spring), the most common 8 psi actuator was a Garrett 0.5 bar (7.25 psi) actuator, part number:
480009-0009
For a while we had some being custom made for us that were already modified to fit our application.
We later switched to an adjustable wastegate actuator. We sourced those from Forge Motorsports and one other vendor (I don't remember the name).
Originally Posted by justmitoy
Anyone have the part number for an 8PSi wastegate spring for lingenfelter tt. Or what wastegate is used ?
I'm new to the turbo world but my understanding is that it is the internal wastegate as came from lingenfelter in the stage 1 kit in 2000. Currently I am running it as it came from lingenfelter on wastegate at 5 psi and would like to increase to 8 psi.
The turbochargers used are an internal wastegate type turbocharger.
The wastegate actuator (that opens and closes the wastegate)
is an external actuator (not built into the turbocharger).
Yes, the base LPE Corvette turbo kits used a 5 psi actuator. At the higher power levels we used an 8 psi actuator Due to packaging/bracket design etc. the stock Garrett actuators have to be modified to fit our application. So the part number I provided is the 8 psi actuator but it will need to be modified (actuator rod shortened and threaded) to fit in the vehicle. Should be able to duplicate what the 5 psi actuator rods look like when they come off the vehicle.
