Which heads on F.I. 346?
I'm looking at an '02 Z06 that has a Procharger psc1 already on it. At some point in it's previous life (40,000 miles) the engine was replaced. Dropped valve? Who knows.
It appears that the car has an LS1 in it now (advertised as brand new crate engine). Why you would use an LS1 if you're putting a brand new crate engine, again, who knows. Lower compression?
I'm assuming LS1 because 241 heads and 78mm Fast intake with BBK 80mm LS1 T.B. Seems like a pretty old school setup.
Short story long, I can pick up a set of stock LS2 (799) locally for $400.00 Canadian pesos (around $300.00 U.S. today).
Does any of this make sense? Is it worth it? Thanks for your input.
Whether its worth all depends who you ask. Stock for stock the 799 heads will flow a little better but to make it worth it, IMO, get them ported or even get your 241 heads ported. Either 799 or 243 heads will work great and flow really well with a good port job. Look into upgrading to a LS6 intake while youre at it.
Or can get a smaller pulley and make a few more ponies as well.
I'm pretty sure that I can get it for 16,500, does that sound cheap enough for a 40,000 mile Z06?
Thank you all for the input so far. I guess basically I was curious if the better flow of the stock LS2 heads would warrant the dollars spent on a f.i. application.
winters97gt (06-12-2017)
LS6 intake came on SS Camaro's once it was introduced in 2001. I'm sure it was on the vettes too. I did an intake swap on my buddies when we could buy ons and I ran 11's with bolt one in his car in high school.
I'd take a good look at the car. Sounds fishy if the owner isn't disclosing full details of motor failure. 241 heads are fine imo for a P1 car. Save the money for when the "unknown" engine craps out.
I know, right? The thing is the guy that has the car for sale didn't do any of the work on the car, it was all the previous owner. He did have the phone # of the shop that supposedly did the installs etc. and I tried calling him but only got a message stating he is booked up solid for the next year and not accepting any more clients.
I agree with your first sentence but, depending on the combo and setup, heads and intake can have a huge impact on a FI car. Cam and heads will usually dictate how efficient a setup will be. Less resistance (efficiency) from better flowing heads and intake will always net more power.
Op, 799 heads will raise your compression. I'd do more research on the car.
Some info from google on heads
http://www.solent-renegades.co.uk/co...ls1-heads.html
The LS1 and LS6 blocks are different too, different part numbers if you can access this to view it.
Allegedly the LS6 block is better...but in real world probably no odds here. And from around 2001 or so most LS1 complete engines would have used the LS6 block anyway.
So the head info above is perhaps a better identifier here.
Of course camshaft could also be different...proper LS6 cam was always considered an upgrade over any other stock LS1 type.
As for pricing, no idea as I'm several thousand miles away and have no idea what the market is like.
But a car with an obviously incorrect engine has to carry a lower value than with a correct engine. Up to you what seems reasonable or not and as to why it has the wrong engine.
True, but he's dealing with an "unknown" 6.0 motor. Those stock 241's are 66cc-69cc depending on the year they were made. 799 heads are 62cc. With that unknown motor, it seems as the car was slapped together. I personally wouldn't touch it, and not slap on heads without knowing what has been done to them.
If I was the OP I would just port them and while theyre off check the block bottom end to see what else he has. Easy enough to do.
I know, I'm the same way. That was such a long time ago that I've forgot most those things. Every once in a while I'll stumble on a post I made from my mustang days since I still read those forums from like 1998, and I'll be "no kidding, I forgot about that".
