What Map sensor do i need to use ???
Old Jul 29, 2017 | 01:23 AM
always faster's Avatar
always faster
Default What Map sensor do i need to use ???
Let's keep it simple:
-2001 C5Z using stock ECM
-427 using a 08 stock LS7 intake;
-Need a clip on type map like a Ls1/ls6/ls2 not one that need a bolt like a ls3;
-Ysi @ more than 14 psi.
So what map sensor do i need?
​​​​​Thanks
Old Jul 30, 2017 | 09:13 AM
Turpid porpoise's Avatar
Turpid porpoise
I pm'd you a clip in 3 bar map. Don't want to get in trouble for posting non supporting vendors.
I think you can also use the zr1 map sensor.
Old Jul 30, 2017 | 09:32 AM
always faster
Thanks for the help, really appréciation
Old Jul 30, 2017 | 10:13 AM
HardcoreABN's Avatar
HardcoreABN
I wil be using the one that comes with my boost controller
Old Jul 30, 2017 | 02:10 PM
always faster
Decide to go oem with a zr1 map with the lpe extension adaptor.
Good up to 30 psi and the maping is a simple copy paste from the zr1 stock data.
Need to be sure using HPTuners 2.24 or newer, otherwise it wont be able to enter the negative value. It's like -11.XX if I recall correctly.
To What Map sensor do i need to use ???
