best option for 8 an line
Im looking to run 8 an line up to my aftermarket fuel rails. Im going to run an external pump with a hobbs switch. Looking for the best place to tie into the stock line. I was just going to y the stock and the 8 an into a single 8an and run it but I need to keep the crossover line.
I thought about tying the two together after the crossover.
What are my best options? I already have 8 an line, afpr and fuel rails.
That's how I did it. The left -8 comes from the big pump, the center is the factory 3/8 line from a Bosch 044 pump and all the fuel goes into the -8 on the right into the rail.
Supporting Vendor
Bret
For a clean look, you could put your regulator in the driver fender area and run the return from there. I have an 8an adapter for the fuel rail and factory line. You can come out of the factory line with the same adapter, go into 8AN Y, and tie it all together in that Y at some convenient place out of sight.
Bret
Bret
I have my external pump in the drivers rear fender with its own filter and then the line runs through the drivers rocker panel before it tees into the stock line on the firewall. Then I have 8AN into a Y going to the back of each rail. Front rails have a crossover and a tee on the drivers rail, from the drivers side it returns to the fpr in my drivers fenderwell and returns back through the drivers rocker panel to the tank.
I was thinking Id like to Y the factory feed to a 8an line like the ECS kit does after the factory fuel tank crossover. I could just get a y block and the appropriate fittings and then a 8 an all the way to my rails. Keep the factory line from the fuel filter to the quick connect after the fuel line cross over. Im sure someone has done this but photobucket as it lockdown so I cant see 95 percent of the pictures on most forums.
