Single turbo location
Old Aug 12, 2017 | 08:48 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Default Single turbo location
What's the easiest place to mount a single turbo? I seen a blue z with a rear mount with that looked pretty simple. I'm not wanting a bunch of power just a few psi and something to do. Any ideas from peeps that done it? Thanks in advance
Old Aug 13, 2017 | 08:48 AM
Turpid porpoise's Avatar
Turpid porpoise
Hinson single turbo kit may be the cheapest/easiest way to go single. Tipot and ruu_vet have done custom front mount singles and danzglass did a single rear mount.
If you are looking to go for it I am removing and selling my ceramic coated hinson manifolds and crossover pipe this week.
Old Aug 13, 2017 | 01:42 PM
001pewter's Avatar
001pewter
Ok thanks, my plans where gonna be a little later on down the road. I was just getting ideas on placement first.
Old Aug 13, 2017 | 04:24 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
The best, fastest single turbo build that I've ever seen came from Lethal Performance and has something in the neighborhood of a 100mm turbo mounted front and center. The thing makes killer power and has been running strong for years now. I think the build was completed around 2014. I found the thread. This car is still kicking *** and taking names.
https://www.corvetteforum.com/forums...rbo-kit-2.html
Old Aug 14, 2017 | 10:14 AM
blackmachdown's Avatar
blackmachdown
Yeah he is always in the 1320video videos when they go to Texas 2k. It's a nice combo!
Old Aug 14, 2017 | 06:17 PM
001pewter's Avatar
001pewter
They look so good setting all purrty up front. I was leaning more towards rear mount, cause I'm lazy and it looked the easiest.
Old Aug 14, 2017 | 08:29 PM
Turpid porpoise
Keep an eye on my build thread and you can see what goes into making a front mount kit. Not all that difficult but you have to be willing to move stuff around.
Old Aug 14, 2017 | 08:31 PM
001pewter's Avatar
001pewter
Will do, good luck with your build.
Old Aug 15, 2017 | 02:56 PM
Supporting Vendor
It'll lose so much heat energy that the spooling will be a night and day difference between that and a front mounted setup.
Old Aug 15, 2017 | 03:30 PM
001pewter's Avatar
001pewter
I've wondered about spooling with it so far back. I didn't know know heat had anything to do with that though. I've also got a old vortec 5.0 that I may wanna experiment with first.
Old Aug 15, 2017 | 03:52 PM
junk c5's Avatar
junk c5
This is my old rear mounted T4 Master Power 70mm turbo spooling from a dig. It sees 15lbs in a reasonable amount of time.
Old Aug 15, 2017 | 04:13 PM
001pewter's Avatar
001pewter
https://youtu.be/LMLVQrE6hv0
That seems pretty reasonable to me.
Old Aug 17, 2017 | 09:55 PM
STL Mike's Avatar
STL Mike
I'm in the market for a power adder, who makes good front mount turbo kits for our C5s?
Old Aug 18, 2017 | 06:58 AM
Turpid porpoise
Nobody makes a production front mount kit except hinson and I have a hinson hot parts kit for sale. Im doing a custom front mount build now and a few others members have done them in the last couple years
Old Aug 18, 2017 | 07:21 AM
StatmanRN's Avatar
StatmanRN
Theres no doubt rear mounts dont spool as fast. However it depends on yoiur priorities. On street tires, it can let you hook before the power hits. With a N2NB box and sticky toies I can make 3-4# on the line. You can brake boost for roll races...And there is always a small ntrous shot for an instant roll hit
Also advantageous for a street car is better wight distribution and less heat unser the hood. Also much easier to work on.
That being said, if you want simple and fast, front mount all day.
Keep in mind a rear mount entails a lot of fabrication.
Old Aug 19, 2017 | 01:29 PM
brenbuchler's Avatar
brenbuchler
How much are you selling the manifold for?
To Single turbo location
