Voltage: 12V
Lithium Cranking Amps: 480
Lead-Acid Replacement Range: 26-35(Ah)
Case Dimensions: 6.49” (165mm) length x 3.38” (86mm) width x 5.11” (130mm) height
Operating Temp: 40 - 140°(F)
Weight: 3.75 lbs
The car will never see cold weather driving and will be stored in heated storage in the winter.
i thought about replacing the battery with the 30 000 mah/400a booster i got for $80. i have to come up with an idea how to solve the charging problem. its powering the notebook when logging so far.
