Strange overheating and fix for it
Now, as soon as he got on highway, engine temp was up to 235 f and interestingly enough, indicated outside temp was over 100 f, which practically never happens here in Finland. In fact, outside temp was something like 71 f. Please note that the outside temp sensor is located near radiator.
I told the customer that it's the splitter - as well as slightly shortened air dam - which is causing problems.
We just removed the splitter, installed A&A kit, tuned it, gained almost 200 hp and while testing at the street, no more overheating. Engine temp was back to 185 f, right where it was before that bloody splitter. :-)
The air dam is there to create vacuum behind it and thus helping the air to flow through radiator.
The splitter as well as smaller air dam did just the opposite in this case.
I've seen this in another C5 as well. That one was without any air dam and had overheating issues. Adding the dam fixed that.
So no need for larger radiator. But of course "your mileage may vary", so it's always case by case.
