Changing fuel system need help
Old Sep 7, 2017 | 08:12 PM
KS Rebuilder's Avatar
KS Rebuilder
Default Changing fuel system need help
I am taking out my stealth pump and going with a dual pump setup using the stock pump with an external pump. I had put in 04 tanks to accommodate the drop in pump but now I will be putting my 02 tanks back in. I am looking at buying a new fuel pump assembly and I came up with 2 part numbers. Old part number 19330864(discontinued)and new part number 19352603. Is there any difference in the 2? I would assume that the new part number has upgraded the fuel level sender part. I have found both for sale with the old part number being a little cheaper. Thanks in advance for your help.
Update: Purchased new discontinued pump.
Old Sep 13, 2017 | 08:09 PM
leo12's Avatar
leo12
why are you removing the stealth?,you should be able to feed the vette with that to over 700 HP
recetronix has a dual set for around $250.00
Old Sep 14, 2017 | 12:38 AM
KS Rebuilder
I talked to Aeromotive about cavitating the pump several times. Their response was if you do it once it is ruined. After the pump warms up a little the pressure drops from 58 to 52 and at that pressure it won't siphon fuel from the passenger tank. It takes 55lbs to siphon the fuel over and the Dyno shop had it set lower than that so all of the fuel was cycling through the driver tank and heating up. Believe me I have looked at dozens of threads about these pumps and the only solution is to replace it with something else. I have purchased everything I need to make the change-stock in tank pump with a external Bosch 44 on hobbs switch. I believe the Aeromotive pump is good if installed and setup correctly but when I purchased it is had not been out for long and the dyno shop didn't set the fuel pressure/voltage controller correctly.
Old Sep 14, 2017 | 08:21 AM
leo12's Avatar
leo12
what i did was get a stock hanger from a junk yard for around $100.00 and buy a dual pump set from racetronix for 250.00 or get a complete lonies perf dual set up for around $600.00 and you good to go,i am pushing over 840 RWHP and have plenty of room to grow, good luck
www.lonniesperformance.com/
To Changing fuel system need help
