LSx Boost Happy intake manifolds
#41
well thats not quite what happened. that track has a stripe at the 1000' mark so i hit the brakes a little early and that's why the trap wasn't where is should be. the bell mouth came lose and nicked the impeller. blower is already at vortech (thanks a&a) and everything else is fine. james' manifold is the real deal!! also, car saw 28 psi on andys 8 rib.
#42
Former Vendor
LS7 Hi Ram roughly 550ci plenum volume to support hp in upper rpm, runners are 6.5" for maximum powerband
Plenum is roughly 10 3/4" from valley flange
3/16" sheet plenum top and bottom, runners are 1/8" sheet, good luck busting this bad boy
#48
Former Vendor
Former Vendor
ohh an update on the mile car
2 out of 3 records set.
The percision 74mm billet turbos are fully maxed out here at 45lbs of boost. Time to go bigger turbos, somewhere around 2000-2200whp at ground through a th400 on a 5.0l zipping to 9100rpm
#50
Former Vendor
Finally got a overlay dyno chart out of my customer Roho Snyper (his facebook name)
Blue line is the holley hi ram on his procharger f1x blower and race air to air intercooler
They approached me to build them a custom air water because they were seeing 200F at the end of the quarter mile.
With my intake they stay at ambient with water only (1.5 gallon total water system), with killer chiller on 15 below ambient.
Tune is nitrous tune but running boost only so rich and no timing in it.
#51
Former Vendor
Been getting alot of requests for ls3 air water intercooled intake so here we go
runners 5" with cnc vstacks (not modeled on)
core 8.1" wide, 15" long, 3" thick, nearly 2k whp worth of core
#53
Former Vendor
Just seeing if it's possible, answer, yes!
Managed to squeeze down a ltx race intercooled (usually about 14" tall) to a tiny 8.5" tall which will fit under a oem gen 6 ss hood and support over 1500whp AND have a full 5.5" runner length!
Pie cut runners to make it happen but where there is a will, there is a way
#54
Former Vendor
Custom turbo kit with my C7 Street Vette Intercooled Intake Manifold
Water only no ice, 20psi boost air temps 280pre intercooler 145post intercooler
e85 street car on stock internals lt4 2017 Zl1 Camaro
#56
It the additional kick-up on top of the manifold for looks or to get the additional volume needed?
#57
Former Vendor
direct port no2
i always aim the tb towards roof of plenum then create a tumble effect into the bottom of the plenum with proper roof manipulation.
In a single tb scenario front feed it is best way to keep an equal air dispersal across the entire plenum
#58
Former Vendor
LS7 Vette (left)
LS3 Vette (right)
going to tack up another ls7 vette tomorrow the the batch 100% welded and shipped to parties.
Getting caught up now that we have flanges and fixturing g2g
For all ltx based stuff soon I will be able to do testing at whim just about any day as my personal lt1 2016 ss camaro is finally coming back to life (going to tuner in morning, looking for 700/700 on 93 oct low boost 5-7psi, big turbo cam and 416 with twin 6766 turbonetics)
LS3 Vette (right)
