Getting e85 delivered
Old Nov 19, 2017 | 08:24 PM
hatewhatownsyou's Avatar
hatewhatownsyou
Default Getting e85 delivered
There’s no stations near me that sell the stuff, does anyone have any other options for what can be done? Idk if I can buy drums and get it delivered or what’s out there.
Options?
Old Nov 19, 2017 | 09:32 PM
junk c5's Avatar
junk c5
https://vpracingfuels.com/product/x85/
Old Nov 20, 2017 | 08:25 AM
cb2004mj's Avatar
cb2004mj
all large manufacturers will deliver a 55 gal drum for you. any shops near by may have a dealership agreement with a vendor and get you a discount too. it tends to be a little cheaper to have it delivered to a business but not necessary. like mentioned above you have VP racing fuels, renegade racing fuels, etc etc. just google 55 gal E85 drum and should show a few options.
Old Nov 20, 2017 | 11:22 AM
hatewhatownsyou
Ok thanks guys
Old Nov 20, 2017 | 05:48 PM
StingrayRebel's Avatar
StingrayRebel
that's a lot of money for some fuel, especially as fast as these cars go through it... how far away is the nearest station from you?... it might be cheaper to get a 55 gallon barrell and fill that up and store it in the garage... not sure of the prices where you are at but in my area you could fill a 55 gallon barrel for about $120
Old Nov 20, 2017 | 09:36 PM
hatewhatownsyou
If I go with e85 I will probably have to go that route.
Old Nov 20, 2017 | 10:23 PM
Millennium FRC's Avatar
Millennium FRC
This is what I was going to recommend.
Old Nov 21, 2017 | 12:17 PM
silver408z's Avatar
silver408z
How much power are you making? Pump gas and meth goes along ways. Just saying if e85 is a pain the *** for you to get.
Old Nov 21, 2017 | 01:22 PM
hatewhatownsyou
I’m at 734, 16psi 10.8:1 compression and 16 degrees of timing.
I’m running 93 and straight meth now.
I have to buy larger injectors so I’m just weighing my options
Old Nov 21, 2017 | 03:09 PM
StingrayRebel
I was around 800 with 16psi and 93/meth but already had fic 127s and then switched to e85 but I was able to keep those injectors but they are close to being maxed now... if you don't want to switch just yet you can buy a big enough injector that will support e85 later on and still work with your current setup that way you don't have to do it twice
Old Nov 21, 2017 | 04:08 PM
hatewhatownsyou
127#’s?
I’m on 60 and was planning to go to 80’s lol (if I stay 93 that is)
Old Nov 21, 2017 | 06:41 PM
StingrayRebel
yeah I had 127s on 93 and meth and duty cycle was in the mid 50s... if you plan on running e85 in the future the 80s won't cut it on ethanol... what is the rest of your fuel setup?
Old Nov 21, 2017 | 06:47 PM
hatewhatownsyou
What duty cycle is considered too low?
I have twin 255lph walbros in the tank, 1/2” line to the oem fuel rail without a return.
Currently have a boost reference to the regulator.
Old Nov 21, 2017 | 06:49 PM
hatewhatownsyou
How much did you gain going to e85
Old Nov 21, 2017 | 08:41 PM
StingrayRebel
you might need bigger pumps if you want to run corn, I'm using two 450's in the tank... I'm not really sure how low is too low as far as duty cycle goes but those injectors were recommended by my tuner and I trust what he says and the car ran fine like that for a couple of years with no problems... when I switched to e85 I did not add any boost and haven't had the car back on the same dyno since swapping but I would guess in the 850-900 range now
Old Nov 21, 2017 | 10:40 PM
silver408z's Avatar
silver408z
I also am running 127's on e85 and meth. Buy bigger injectors than you think you will need. E takes 30% roughly more fuel than 93. Leave yourself room to grow and just in case 80's are not enough.
Old Nov 22, 2017 | 07:54 AM
hatewhatownsyou
Are you guys spraying the same amount of meth as you were with 93?
To Getting e85 delivered
Old Nov 22, 2017 | 09:27 AM
StingrayRebel
my meth kit is still there but I'm not using it
Old Nov 22, 2017 | 10:03 AM
ysb02's Avatar
ysb02
Delivered e85 isn't cheap at all which sorta ruins it's benefits. It's cheaper than C16 but not by a lot.
I was thinking of switching only if I kept a 55gal drum at home that I filled up from local pumps.
Old Nov 24, 2017 | 09:43 PM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
If you buy Ignite Red E85, the cost break maxes out at one full pallet or 4 drums. With 4 drums, It cost 1550 delivered without lift-gate service making it 7.05 per gallon. That's quite a bit less than I pay for C16.
