Largest "quiet" centrifugal?
So, I much prefer helical-cut gear sets because they are nice and quiet. From what I can tell, the Novi 2200 seems to be the largest unit available with helical-cut gears. Is that right?
Is there a Vortech model under the YSi that is equal to the Novi 2200? The JT-trim is basically a Novi 2000 with a cast case, right?
JT is equivalent to the 2200 but I do not believe it is available in helical gear set. Ti trim would be the biggest.
FYRARMS (11-20-2017)
Thanks, guys. Potentially buying another C5Z that currently runs an A&A V3 Si kit. Looking to swap head units for something with more oomph. I think the Novi 2200 will be my best bet.
Not too bad! I would definitely put the hush on the Bubba, though. I like quiet and stealthy under acceleration. The 38mm with filter on the car now is almost silent under part throttle.
