Which torque tube couplings and bearings?
Going to install a new clutch and tr6060 over the winter. I think I should do the couplings and torque tube bearings while Im in there.
Which couplings should I get? Car will be supercharged while making close to 700 rwhp. I see there is OEM style rubber, poly and billet couplers. Which one should I get for my horsepower level? I do not want it to cause vibration or other road noise if I can avoid it.
What about bearings? I see RPM has torque tube bearings for 190.
What are my best options?
Thanks!
Thanks!
I did the poly couplers in mine after doing the same research as you. I'm at 765 rwhp, no issues. Replaced all the bearings while I was in there as well. Got the entire rebuild kit from RPM transmissions. You can piece it together slightly cheaper if you look around, but I chose customer service over lowest price.
Leeland
Leeland
Leeland
Leeland
Any added drivetrain noise with he poly couplers?
https://nemiga.com/cat_spares/epc/ch...y/05/1y05-066/
Coupling - Qty: 2
Part Number: 19299915 or 88894026 or VTRB-12
SKF Bearing - Qty 1
Part Number: 6007-2RSJEM
SKF Bearing - Qty 2
Part Number: 6008-2RSJEM
Bolt - Qty 12
Part Number: 88894027
Seal - Qty 1
Part Number: 12456203
Seal - Qty 2
Part Number: 12456220
Ring - Qty 1
Part Number: 12456209
Ring - Qty 2
Part Number: 12456222
Slinger - Qty 1
Part Number: 12456208
Coupling - Qty: 2
SKF Bearing - Qty 1
SKF Bearing - Qty 2
Bolt - Qty 12
Seal - Qty 1
Seal - Qty 2
Ring - Qty 1
Ring - Qty 2
Slinger - Qty 1
Mike94ZLT1 (12-11-2017)
I have a 2000 making 600rwhp. Have stock DS and couplers in until last season. Toasted my rear end at the strip so figured it was time to upgrade since everything was gonna be mostly apart. To my surprise everything looked great. I ended up keeping the stock DS and going with RPM Rebuild Kit (rubber couplers and bearings). No vibrations.
I went with solid motor mounts, solid diff mounts (have TR6060 and ZR1 diff) and a DSS Carbon Fiber shaft (eliminates couplers). Considering all that its not bad at all on NVH. Nothing I can really hear or feel over the sound of the motor.
