Just wanted to check in on my C5 F.I. Pals
ISIS SUCKS FAT CHOAD
How’s everyone doing? I haven’t been on here in awhile. Just thought I’d check in and see what’s new? What kind of cool stuff are you guys building?
Doing fine here. I am finally a few hundred dollars worth of aluminum away from getting my pile on the street where it belongs. I finally got my radiator mounted without any zip ties or string holding it in place, surge tank is plumbed up, revised IC hot side piping is done, all I have left is make the radiator pipes and revise the cold side charge tube and I will be headed to the dyno.
Heres a few recent pics of the build:
Rad and Shroud
Engine Aerial View - Cold side now goes to drivers side of IC and hot side goes to passenger. With how little clearance there is between the wastegates and the charge piping I did decided I would rather have the hot side over there. So it's half way redone.
Fuel Surge Tank - The lines are all completed at this point and are all organized and tied up using billet hose separators.
Bulkkheads through floorboards
Lots of hose
Rad and Shroud
Lots of hose
MVP'S ZO6 (01-29-2018)
