Shortened radiator fan setup
Old 02-05-2018, 02:14 PM
hatewhatownsyou
hatewhatownsyou's Avatar
Default Shortened radiator fan setup
I’m just trying to research and plan ahead a little bit, current setup is stock radiator/fans, A&A Supercharger setup with the spacers under the rad support
I ordered a 3” cutdown radiator, and would like to remove the spacer under the rad support. I plan to make an aluminum shroud with 2 11” spal fans.
Guess my question is, has anyone done this and will regular profile fans clear the sway bar or do I need the lower cfm, slim fans? I think raising the support up will help with the fan clearance issue also.
Old 02-05-2018, 04:08 PM
leo12
leo12's Avatar
I have done exactly that with the larger spals with out any problems with the sway bar and I'm using the larger T1 sway bar,
Old 02-05-2018, 05:10 PM
silver408z
silver408z's Avatar
I going through a build on my car. Blownbluez06 is doing the work and he built me a custom radiator cradle. The cradle stands the radiator straight up. It also is using a cut down radiator. The setup lets a large intake and charge pipe fit with no problem and increases cooling.
Old 02-05-2018, 07:03 PM
hatewhatownsyou
no spacers and thick spal fans? Did you have to modify anything with the support back in the factory location?
Old 02-05-2018, 07:13 PM
hatewhatownsyou
Silver 408, I’m assuming he had to lower the radiator slightly to get it to clear completely also.
My main concern is with the fans and what ones will clear
Old 02-05-2018, 08:13 PM
dopefedz
dopefedz's Avatar
You can get the stock fans to work with the short radiator. Pretty easy to take stock cradle apart and move the radiator mount up some to get clearance for everything.
Old 02-05-2018, 11:41 PM
jmuck
jmuck's Avatar
I modified my cradle to stand my cut down Dewitt’s straight up and can clear a 5” intake. I’m using a dual fan set up from Jegs that works great.
Old 02-09-2018, 08:47 AM
hatewhatownsyou
Im gonna make this out of 1/8 plate, and wait to cut the fan holes till I get it all installed to make sure it’s going to clear.
The shroud is within 1/4” or less for the radiator so I’m gonna just use some wide foam sealant tape to seal it up
Old 02-09-2018, 09:13 AM
Turpid porpoise
Turpid porpoise's Avatar
Have you thought of putting a rubber flap or two in there to allow air to pass through when the fans are off?
Old 02-09-2018, 11:34 AM
hatewhatownsyou
One main thing I should have pointed out is there there will be 2 fans,I only have one on the paper
Thought about it? Yes
But seeing how 75% or the shroud area will be the fans I shrugged them off. I could put two between the fans in the radius area but I didn’t think it’s necesarry.
What’s your opinion?
Old 02-09-2018, 11:36 AM
Turpid porpoise
I'm kind of in the same boat. I've considered putting a couple in but have taken no steps toward doing so.
Old 02-09-2018, 12:03 PM
jbsblownc5
Support Corvetteforum!
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
I have been running the Dewitts shorter Rad and their shroud/duel spal fan set up for a few years now, works and fits GREAT!
Old 02-09-2018, 12:46 PM
hatewhatownsyou
3” x 1.625” is about all I can fit
Old 02-10-2018, 07:57 PM
hatewhatownsyou
3” shortened radiator with the cradle still lowered.
4” intake
Old 02-13-2018, 09:36 PM
hatewhatownsyou
The condensor stuck about 1.25” above the radiator, so I cut off the tabs and welded new ones on to lower it. Keep my fingers crossed it doesn’t leak
Old 02-14-2018, 07:35 AM
Turpid porpoise
Remove it all and wire in a small 12V fan in the cabin lol. Thats what I'm doing.
Old 02-14-2018, 09:25 AM
hatewhatownsyou
Meh...these cars are miserable without ac lol
S400z06 (02-16-2018)
Old 03-16-2018, 05:57 PM
hatewhatownsyou
Decided to ditch the 2pc intake and just make my own. Test fit to see where I need to weld the bungs in for Iat and meth nozzles. Going with 2 #7’s after the intercooler and one #3 before the blower. (Same as what I had before).
Once I get them welded up I’m gonna brush the pipe and send it out for black anodizing
I’m also going to be able to use the A&A top shroud, just trimmed it for the new piping and for the shorter radiator.
To Shortened radiator fan setup
Quick Reply: Shortened radiator fan setup
