What to expect...
Old Feb 10, 2018 | 11:20 PM
-WhItE_NoIsE-'s Avatar
-WhItE_NoIsE-
Default What to expect...
Hey guys curious what y’all are making on yalls YSI’s and think I can make on my setup. I’m currently swapping in Texas Speed 436lsx 10:1 compression, Texas Speed cam 240/251 657/657 116, LS7 heads and 102fast, A&A YSI with 2.70 pulley, e85, id1700 injectors, kooks 1 7/8 LT’s, corsa extreme exhaust. Thanks guys
Old Feb 11, 2018 | 12:13 AM
silver408z's Avatar
silver408z
Looks like a good setup from my amateur perspective. Seems like a solid 1000 hp setup.
I would probably not use a fast intake. They are known for cracking and having boost leaks. Some people use them and never have a problem and some people use them and have constant problems. Kind of hit and miss. The factory intakes are known to be stronger and lots of people have made big power on them.
I am having a similar build done on my car but I will be using a f1r till the budget allows a bigger blower. There is a build thread on here about it and all the work is being done by Blownbluez06.
Old Feb 11, 2018 | 02:28 AM
-WhItE_NoIsE-
I’ve heard fast or stock LS7 manifold is way to go, but figured fast would be better. I’m wanting 1000rwhp+ We are doing flexfuel with a 04z pcm.
Old Feb 11, 2018 | 08:49 AM
helga203's Avatar
helga203
(Unreal) i believe has a setup like yours and he was around 1200rwh. Look him up.
Old Feb 11, 2018 | 11:09 AM
-WhItE_NoIsE-
Looked him up couldn’t find any numbers anywhere.
Old Feb 11, 2018 | 02:17 PM
silver408z's Avatar
silver408z
I am doing a stock ls7. I just did not want the potential headaches and what blownbluez06 recommended. We did have it painted gloss black.
Old Feb 11, 2018 | 04:56 PM
-WhItE_NoIsE-
Kevin at M2K Motorsports is going to see if place we ordered fast will take it back if so I’ll buy stock LS7. Unreal thinks my car should make 1100rwhp I’d be freaking pumped if I make 1100rwhp. I’m just use to people saying they only make 900-1000rwhp.
Old Feb 11, 2018 | 06:48 PM
itsslow98's Avatar
itsslow98
OurYea id be more concerned how you're going to use that type of power efficiently. If say over 1k for sure
Old Feb 11, 2018 | 09:38 PM
-WhItE_NoIsE-
Drag radials or slicks
To What to expect...
