C5 with ProCharger D1X
typeav (02-18-2018)
Picking up the car tomorrow, I was told can't dyno until clutch break-in period, it does have a tune but just to cruise in the meantime, shortblock is stock ls1 with blower cam and 799 heads. The minimum we expecting should be around 600rwhp Mustang dyno with 4.25" pulley. I'm way over the limit already, I will keep this post updated.
Received 1,261 Likes
curious to see how it turns out
Previous mustang dyno as N/A result 409 rwhp / 394 tq
Here are the result, when driving around like under 3k rpm the car feels slow compared to how it was before without procharger, I missed spinning tires at every corner under normal conditions. But when I step on the gas the car respond very quickly and really start it kicks in after 3k rpm. I haven't pass the 70 MPH yet, it just came out of the dyno.
CURRENT MODS NOW
ProCharger D1X 4.25" pulley with twin intercooler
LS1 stock bottom end
Fast Intake LSXR 102 MM
LS2 Throttle Body
Fast 60 lbs Injectors
BAP MSD 2351
799 Heads
Spark Plugs NGK TR6
CompCams XER273HR - 224/230 Duration, .581/.588-Inch Lift, 114 LSA
CompCams 26918 KIT, Beehive valves, Titanium Retainers, Springs Seats,
CompCams 7.350 Push Rods
CompCams LS Heavy Duty Rocker Arm Bearing Assemblies
REV Stainless Steel Valves 1.57 - Exhaust set of 8
REV Stainless Steel Valves 2.02 - Intake set of 8
LS7 Lifters
GM High Volume Oil Pump
Headers LG Pro Long Tube w/Cats & X-Pipe
Exhaust Corsa Indy Pace Car Quad 3.5" Pro Series Tips
Black Hawk Brake Pads
McLeod Twin Disc (Organic)
and a bunch of others things
CURRENT MODS NOW
LS2 Throttle Body
BAP MSD 2351
799 Heads
Spark Plugs NGK TR6
LS7 Lifters
well how many races are you in that are at or under 3k rpm?... spinning tires is no good in a race so appreciate the traction... it looks pretty solid though... how much boost did it make with that pulley?
Can I say first C5 with D1X ? ..... Ahh doesn't matter, this is what a C5 looks with a D1X
https://youtu.be/ZOA-fiAsF-U
I was going to upgrade my D1S-C to the D1-X......which gear set is that? Standard or Hellical gears??
i'm curious to what intake mods changed from the N/A setup, to make it feel slower under 3k. my guess is you didn't have the Fast 102 before? the butt dyno is more sensitive to low end torque. could be a runner length "issue" that makes it feel that way, the cam spec doesn't appear that aggressive
No intake change at all, other than the vararam to procharger, always had the fast 102mm intake, is not that is slow because as you can see from the N/A dyno with the procharger shows more power at low end but when you driving around you can feel the low end torque is missing while cruising
For example, is like a ported throttle body, it doesn't give you horsepower but become more responsive while driving around, maybe my pulley is to big or going from stock to twin disc clutch makes any difference as it was upgraded at the same time. ProCharger dyno sheet was tune in another dyno by different tuner using HP tune.
Saying this, I do have to confirmed the car pulls hard very quickly to the point that I can't watch the speedometer anymore like before, can't take my eyes away from the road.
maybe the tune was softened up on the low end since you're on a stock block?
interesting, It's probably irrelevant, but my OCD is curious of what mechanical change happened, that's all. especially since it's a centrifugal car.
my next guess the procharger and intercooler is more restrictive than the vararam, robbing the intake velocity, until the boost comes in. good point on the tune also, can throw some timing back in under 3k to get some extra torque down there.
this can be a possibility as they want my engine to last
mechanical change
none
if I step the gas on low end the car goes aggressively wild, if there is any resctriction it should not react like this ? there is no lag
this can be a possibility too, I asked and they told me because under 3k rpm there is no boost
this make totally sense, I should ask the tuner exactly what he knows as this tuner comes in scheduled appointments only, he's not full time in the workshop
mechanical change
none
I put a ysi trim on stock ls6 with a huge pulley on making about the same power. It feels more sluggish idle->2.5k. I just thought the sc was robbing hp/torque
Is the new cam just trading off low-RPM performance for higher-RPM performance?
How long are the runners in the new intake manifold? If they're shorter that could also shift the powerband up.
That said, those dyno charts show about 320 ft-lb at 3000 RPM before the supercharger, and 450 @ 3000 with the supercharger. Are you sure it's really gotten weaker? Or is your butt-dyno just getting confused by how much MORE torque you have now from 3000 to 5500 RPM?
