Catch can for centri set up
Old Mar 6, 2018 | 02:34 PM
Podium's Avatar
Podium
Default Catch can for centri set up
Is a catch can a good investment for a supercharged motor? I have an ls6. Just wondering it it really helps or I should spend money elsewhere.
Old Mar 6, 2018 | 03:24 PM
silver408z's Avatar
silver408z
Yes it is a good idea. Get a good one, especially since you are using forced induction. I personally went with a mighty mouse setup.
Old Mar 6, 2018 | 03:28 PM
AltitudeCO's Avatar
AltitudeCO
+1 for the MM setup
Old Mar 6, 2018 | 03:32 PM
Podium's Avatar
Podium
That's the brand I would go with
Old Mar 6, 2018 | 03:57 PM
AltitudeCO's Avatar
AltitudeCO
Had it on multiple cars, great setup. Worth the investment
What is your SC setup out of curiosity?
Old Mar 6, 2018 | 04:22 PM
Podium's Avatar
Podium
Its an 01z with A&A TI kit. Full exhaust with a cam.
Old Mar 8, 2018 | 11:41 PM
Jimmy WS6's Avatar
Jimmy WS6
I have the exact same build as you. Car made 713/565. Buy a Mighty Mouse catch can. I did
Old Mar 9, 2018 | 07:14 AM
ysb02's Avatar
ysb02
I like the catch can setup since it previously just had a line running from the oil filler to air filter. I didn’t want oil or anything being sucked through the sc.
Old Mar 9, 2018 | 08:15 AM
TTBlueZ06's Avatar
TTBlueZ06
-10 vents off both valve covers to a vented can... Best way you can do it, vented to atmosphere.
Old Mar 9, 2018 | 11:24 AM
dopefedz's Avatar
dopefedz
Like TTBlueZ06 said -10 or -12 bungs welded to your valve covers and run them to can. Easy to do.
Old Mar 12, 2018 | 10:45 AM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
I'll add that bung location is important. All of the oil in the head runs to the rear, under acceleration so I try to put them forward of the very back and up top, of course. When space permits, I also prefer to weld in a baffle to help prevent oil from coming along with the crankcase gases. The larger diameter, the lower the gas velocity, which also helps. Also, no diameter ever seems large enough when the motor gets hurt.
Bret
Old Mar 13, 2018 | 08:50 PM
Podium's Avatar
Podium
I've read that. Can you Y them together or run separate lines to the can? What about the pcv?
I think I'm going to order a Mighty Mouse can set up this week.
Podium's Avatar
Podium
Which can did you go with and how did you run it?
Old Mar 14, 2018 | 08:33 AM
Turpid porpoise's Avatar
Turpid porpoise
Avoid bring the lines to a Y because you will then restrict flow. Say you have a 10AN bung on each valve cover but they Y into a single 10AN or 12AN, it will only flow as much as the single line they Y into.
I used the PCV can when I was supercharged but now I have a PCV can and a draft can. PCV can is installed between the intake manifold PCV barb port and one valve cover port(dirty side). The draft can is installed between the other valve cover port and a 10AN bung I welded on my turbocharger intake tube(clean side).
Old Mar 14, 2018 | 04:04 PM
Podium's Avatar
Podium
I havent talked with David yet but it looks like with his system you plug the ls6 valley pcv?
Im hoping to run one can.
Old Mar 15, 2018 | 11:37 AM
David@MMS's Avatar
David@MMS
Supporting Vendor
hello!
happy to answer any specific questions, chipping away at any voicemails now as well.
Old Mar 15, 2018 | 11:44 AM
Turpid porpoise
David can answer this but according to his diagrams, yes you do.
Old Mar 15, 2018 | 12:03 PM
Podium's Avatar
Podium
I spoke with David and he told me that instead of us8ng the driver valve cover, you can use the ls6 valley pcv barbed port to the supercharger. This is what I plan on doing to keep the install clean
Old Mar 15, 2018 | 02:50 PM
David@MMS's Avatar
David@MMS
Supporting Vendor
the valley plate and some ls cars and trucks, the driver cover are most commonly used as the pcv system flow regulation point, controlling manifold vacuum application to the crankcase.
-when we have the catch can take over this job, as is the case with my PCV can (this can comes in most of my wild systems), these ports are no longer required for their original job, and are usually capped but sometimes need to be used as a nice baffled point for fresh air supply
To Catch can for centri set up
