17" vs 18" rear rims - racers step inside
Im fairly new to this but everyone that races is telling me wide doesnt matter its tire height that matters for traction. I have friends running 275s but taller like 50-60 vs my 315/30. I have no sidewall. They hook I dont.
Wheels/Tires ( M&H 275/50/17 ?)
I have an 01 Z06TT and also want to keep the stock wheel look. Stock I have front 17x9.5 and rear 18x10.5. Im going to switch these and put the 18s on front and 17s on rear. I have a friend that did this and runs M&H 275/50/17 and it fits. Im going to try MT ET street R 305/45/17.
275/50/17's?
Posting here caause I know a lot of you FI guys are drag racers. I'm doing a FI build that hopefully will be around 750 Flywheel HP in a car with all the standard bolt on's. It a 2003 that will have a LS2 forged lower transplanted. Running gas as fuel, a RPM A6 and 3.42 rear.
Now to the problem. I have polished thin spokes on stock stagger - 17" front, 18" rears. I want to keep these wheels. Yes I like them and will keep them. I want stealth for the street as well as the strip. The car will do occasional duty at the local 1/8 mile drag. I will be fitting drag radials to what ever rear rims I use. I will be keeping the 17" fronts but I have access to another set of 17" thin spoke fronts that could be widened for duty on the rear.
I think it about $250 per rim to widen. Is the 17" rims worth the cost in terms of traction and tire availability or should I just say good enough and run the origial 18's
