Injector size for e85
Old May 4, 2018 | 01:54 AM
nfantbabyjesus's Avatar
nfantbabyjesus
Default Injector size for e85
Have a 00, a&a si, btr jam cam, full exhaust, 3600 stall, Dw350 pump, ptfe lines, Wix C5 fuel filter/regulator.
Car has been supercharged but cam, stall, and fuel setup installation is under way. I'm currently running 60# but I'm contemplating tuning on e85. Was wondering how much of an injector I would need?
Old May 4, 2018 | 08:03 AM
Podium's Avatar
Podium
https://www.corvetteforum.com/forums...countered.html
I would also plan for the future aka buy bigger than you need in case you wanna up the boost.
Old May 4, 2018 | 10:26 AM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
I would recommend going with a set of Fuel Injector Connection 127's. They're large enough to cover your power, E85 compatible and able to operate slowly enough to not cause idle issues.
I updated the fuel injection system calculator if you decide you want to download it and play with it. Let me know if I can help.
Bret
Old May 4, 2018 | 03:07 PM
Rkreigh's Avatar
Rkreigh
Bret
that's what I went with as I heard they had good behavior and Jon gives me a good guy price from my ZR-1 days when we bought 16 at a time
Bret, ever do staged injectors with the haltech? I'm dying to install mine and need to move out! the way I have it now is 127 injectors and flex fuel and direct port alchy and a pump amp box from the haltech on a channel to allow for days when I'm too far away from e85
a bit of overkill I know, but that's the way I like it.
I have a big tank in back and I'm also looking for a pump that will do alchy and race fuel. I understand race fuel through an alchy control pump isn't a good idea but I like the idea of being able to tune on both :>
thanks!
To Injector size for e85
