MSD 2 step
Old Jul 2, 2018 | 05:48 PM
TheBandit18's Avatar
TheBandit18
Default MSD 2 step
So I'm a bit confused on the activation switch. If I hook it up to the clutch pedal will it still be active when I shift? Does it mess with anything when you shift? So in that case would it be ok to just hook it up to a momentary button on launch?
Old Jul 2, 2018 | 08:31 PM
junk c5's Avatar
junk c5
I believe this should answer your question..
Note: The engine rpm must drop more than one third of the set launch limit in order to activate. For example, if the launch limit is set at 3,000 rpm, the engine speed must drop below 2,000 rpm in order for the launch limit to become active (one third of 3,000 rpm is a 1,000 rpm drop).
Old Jul 2, 2018 | 10:21 PM
TheBandit18
well people are saying their car pops between shifts after installing the 2 step. I get what that is saying just seeing if anyone has had problems with that or no.
Old Jul 2, 2018 | 11:34 PM
junk c5's Avatar
junk c5
Gotcha, I’ve got the MSD 2 step on my car but it’s an auto.
To MSD 2 step
