NX Express Wiring Harness
I never looked into NX's harness, but when I inquired with outlet about their harness, it was going to be 700 some dollars and wired for their controller.
I made my own panel of items to use for the electronic side to mount in the trunk,
I need to tap into the harness for the TPS. I don't want to splice into it or use a wire tap. My idea was to make a small harness that would go in between that used factory connectors.
The other wiring looks to be pretty straight forward.
The board you have seems rather busy. I assume the NOS box is a window switch. What are the other relays for?
The smaller of the two relay boards is for the heater activation. It is a single, 70amp relay board that my switch leads go right to. Once again, makes terminating wiring ends much simpler, IMO.
Good thing you mentioned the TPS signal.. Now I have an LS2 throttle body on my C5Z so I use the casper adapter harness. I too though of how I could make the "splicing easier" for this signal, and also the method I used will be the same for the tach signal at the pcm as well.
Here is what I did...
Using a single pole weather pack connector.
The larger of the other two relay boards controls the activation of the nitrous/fuel solenoids channel control from the NOS Mini as well as a secondary relay control for the purge solenoid. This board from leash electronics makes the wiring 10x easier to think through.
