Lowered turbo car?
Lowered turbo car?
Got what I think is a dumb question. I lowered my 2000 TTI car on stock bolts and it seems to be running about 5 to 10 degrees hotter. Will lowering a car reduce the air flow? Common sense tells me it could but just not sure
CorvetteBrent (08-27-2018)
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
My car was lowered before the turbo kit and I saw zero increase in temps after it was on the car. Does your TTI kit use the twin side mount IC's or a single front mount? If it uses the single front mount then lowering it may have played into the airflow through the IC/Radiator perhaps?
What did ambient temps do since lowering it? Did you have to trim the rubber radiator splitter?
My my kit has the front mount intercooler. I just recently opened up the front license plate may have helped a degree or two
