Highest compression for turbo
Old 10-20-2018, 11:00 AM
2f@s4u
2f@s4u's Avatar
Default Highest compression for turbo
I have a 408 stoker with 11.5:1 CR. TEA ported 799 heads and comp cams 239/247 cam 624/624 lift. Can I safely run a single turbo on this setup without any cause for problems. Obviously I would have to upgrade to a turbo cam?
CorvetteBrent (10-21-2018)
Old 10-20-2018, 05:23 PM
itsslow98
itsslow98's Avatar
As long as you use meth or e85 you will be fine. Or low boost on 93
Old 10-20-2018, 05:44 PM
stevieturbo
stevieturbo's Avatar
Depends on piston design, fuel, boost, goals, tuning etc etc
Old 10-20-2018, 10:22 PM
junk c5
junk c5's Avatar
I would try it. Somebody has to try pushing the envelope or testing the waters. LOL. I’d go E85, custom spec’ed cam and the thickest head gasket available for piece of mind.
Old 10-21-2018, 10:17 AM
blackmachdown
blackmachdown's Avatar
Pick up a set of 317 heads to drop compression if sticking with pump gas, otherwise meth or e85 and let her eat
Old 10-22-2018, 06:48 PM
Ronnie_W
Ronnie_W's Avatar
I bought a 402 LS2 with 11.5 compression. Added a .060" gasket and 317 heads. I lifted a head at around 20 psi boost. I then went with a .100" gasket, some 72 cc heads with a 3/4" deck and it has been fine so far with 93 and meth. I'm going with e85 soon. Mine is a Huron twin turbo.
To Highest compression for turbo
Quick Reply: Highest compression for turbo
