Need some input on tuning
C5 LS1
A&A v3si
stock internals, long tubes, x pipe, b&b bullets
alkycontrol system, m15 single nozzle
Long story short..got everything installed and got it tuned. Made 530 without meth..was planning on running 100% meth, but tuner convinced me to run boost juice which is 50/50.
Made 537 on 50/50. The **** is set on 3.5.
First, all of the reading I’ve done on here, the alkycontrol **** should be at 4 or greater due to the controller being erratic below 4.
Secondly, shouldn’t it have made more power on the 50/50?
I understand the reasoning behind running 50/50, but now I’m really questioning my decision to not run 100% meth...
What would you do in this situation?
A&A v3si
on a conservative tune at that hp level it probably doesn't really need meth. Tuner recommended boost juice just for safety and to keep it out of detonation which really shouldn't be an issue unless you run junk 91 octane fuel which is all that is available sometimes.
I'm always going to recommend pure meth as it will always give you the cooling and hp you seek. What boost are you running? below 8 psi or so, I don't think meth would do much to help you. you just need a whiff of it at low boost.
C5 LS1
A&A v3si
A&A v3si
1. Never use 51%+ Meth because of invisible fires/catastrophes possible. There may be some racing applications where the risk is worth the weight, however for most of our 'enthusiast' applications it isn't worth the risk...
2. Water injection component lowers power. Its like pissing on a fire. The water absorbs heat thus reducing EGT and making the engine safer to run. Methanol could be considered a racing fuel, like ethanol, so while it raises octane, it does not help with EGT nor does it cool the components of the engine where it burns.
Your tuner is smart to recommend 50/50 for its octane boosting, and temperature lowering benefit, as a safe liquid that will not create a fire if it starts spraying all over the place. I would keep it 50/50 and if you want more power, turn up the boost. The 50/50 just makes it safer to run more boost- it by itself does not 'add' power nor should you expect additional power 'on' the methanol. Higher octane fuel (i.e. C16 aka leaded aviation fuel for example) does not increase power- it reduces power (higher octane fuel = less power all else equal). It merely allows you to raise the boost or increase the timing in search of more power.
If you cannot turn up the boost for some reason (out of compressor flow- off the map) you can either increase the size of the compressor (upgrade the turbo/blower) or reduce the amount of high octane/water going in (at the risk of getting too hot, or having a violent explosion due to lower octane). Or of course you can always inject more 'air' (nitrous)
