Does anyone know how and where to splice the wire for the full throttle position sensor for a nitrous car? There are like eight wires to choose from coming off two different sensors on the throttle body. One on each side. I need to know which one to go off of and then which wire to choose from that side.
Dont waste your time with that sensor. I would go with the mechanical one that goes under your pedal. Tuan & the rest of us have had so much trouble with it.
:yesnod: :yesnod: :yesnod:
Maybe you should buy mine @ 1/2 price so you would have two for redundancy. :lol: :lol: :lol: :jester
Anyways, back to you question....You need to tap into the dark blue wire on the passenger side connector. :cheers:
i have a lot of problems with the mechanical WOT switch. the spring steel bends and then i go to spray the car and it is a no-go! i am tired of having to constantly adjust it. what kind of problems does the TPS one have? i would be interested in buying one for half price if it would solve my problems......will it work on an lt1?
