People running fore fuel systems, i have a few questions
I just ordered my Fore triple setup w/ 450s and just have a few questions for you guys that have tackled this install before.
1) How did you run your lines and fuel filter
2) Where did you mount your FC3 controller
3) Anything you wish you would have known going into the install that you know now? Im failry certain with tripe 450s everything has to be installed inside the tank which im not looking forward too, but i plan on pulling the rear cradle and trans and doing everything on the work bench to try to make life easy as possible.
Lines and filter thru the driver side rocker panel.
fc3 controller is mounted in the wheel well on the driver side
haven't removed the newer style tank with the pumps up top but I can get the older one out in about 10-15mins lol.
Im not running a fore system but I do use their controller to run my dual 450s. 10an feed 8an return.
I have my FC3 in the center of the trunk mounted to a plate that is mounted to the fiberglass tub. I used one Deutsch bulkhead connector to run all the wiring out of the trunk to the pumps, just make sure you get a connector rated for the right amount of current.
