build finished and new dyno numbers.
#81
Received 1,261 Likes
let's not all jump to conclusions...
Turbo-Geist (01-04-2019)
#82
Turbo geek
Little turbo-fart i can buy u like a cheap *****. Go back into your closet and turn yhe lights out so you can be the internet macho man you think you are azzhole.dont you wish you chitbox made that much power turbogeek. Shut it down close the door and keep whacking.
#84
How about you buy a dyno sheet instead.
#85
Here was my initial expectation in 2013 of how a cam only stock LS1 with twin turbos and a stock 6 speed manual should run at the track. It made the 50 mile cruise both ways under its own power. I can't name who built the engine because it was built by a GM worker at the factory in 1999. I do my own wrenching and tuning so no need to reference a shop's name, address or telephone number. Oh and I have an engineering degree but I know plenty of people on here that do just as well with their builds without an engineering degree or owning a shop or labeling themselves professional "tooners". You said mph is a good indicator of horsepower at the track. Show me your mph.
#86
your car is a turd. a weak azz non z06 coupe. had one that was supercharged and automatic.also had good dyno numbers but not as fast as my z06. I am no hurry to take my corvette to the track. it is still a work in progress. I have other corvettes and other cars. have a twin turbo cadillac xts as my driver. my mustang was a purpose built drag car and can take constant runs all day without issues and with slicks and wheelie bars with parachute. the super comp dragster i licensed with ran 8:20 at 170 mph. not impressed since the rail goes so straight and smooth unlike short wheel base cars. I am not comparing one car from another. just posting my dyno results. thats it. If I wanted another drag car I would have built one. I am not much of a drag racing fan like before. I am more of a optima street car challenge guy instead and also like 1/2 mile runs.
#87
#88
You are in luck as there is a half mile event in your neck of the woods this month and you said your car is running great. I look forward to your future post with a mph slip from this event.
#89
ISIS SUCKS FAT CHOAD
I'll be Wyatt Earp and state the following:
Why are you listing 875hp at the engine and then starting the calcs with 840hp?
Why are you choosing 0.6 BSFC?
Have you accounted for the horsepower loss required to drive the supercharger?
These calculations do not take into account the pressure losses in the system. Also fuel pump curves are non-linear so it's not a 1:1 ratio with voltage and flow.
Kenne-Bell makes two different Boost-a-Pumps. One puts out a max of 17.5 volts and the other 21V. Which one is on this car?
These are just some real world things to think about...
most importantly there’s a gentleman on these very forums who I saw personally take his T trim set up and break 700 wheel on a mustang dyno. On a SBE LS1. He did it 5 years ago. He ended up putting a single 15 gph meth nozzle on the car but it did 706 or something like that without it. He was in a stock fuel pump and a BAP and 60s.
Just because its crazy or you havent done it don’t mean it’s impossible especially if the math somewhat ball parks.
All I’m saying is let’s not be so quick to stomp on this guy (even though he is being a bit defensive)
Ps... hows tour ride doing?
#90
Who knows what BAP he has I don’t and it’s not that important. All I’m saying is even if you use 875 and .6 go it’s still doable.
His attitude is what set everyone off. Also, why not show the dyno sheet? He’s had enough time to post it. I’m sure people would have doubted the 800 plus I made with my TI set up but I also posted the dyno sheet in the same thread.
Hes on a car at forum and has the ability to post his sheet. It’s the same thing as being at the gym and saying “oh, I can lift that but I just don’t want to” after bragging about being able to do it.
#91
#92
700 with methanol is still way more believable. 15 gph or ~95 lb/hr of methanol taking load off the injectors and fuel pump and the additional octane.
Also his story doesn't add up, he claims (multiple times) 699hp at 6200 rpm and 547 torque. You would need 547 torque at 6700 rpm to hit 700. You'd need 592 torque at 6200 rpm to hit 700 hp. Then his defensive childish manner and refusal to post the dyno sheet started this mess lol.
