SC Pulley Question
Old Dec 13, 2018 | 06:59 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default SC Pulley Question
I have a stock size ATI crank balancer with a 3.5in SC pulley making around 10lbs of boost,Im going to a IW 10% OD 8.5in. crank balancer,Roughly what size SC pulley would i need to get to keep it the same boost? 4"?
Old Dec 13, 2018 | 07:37 PM
silver408z's Avatar
silver408z
https://928motorsports.com/services/selectingpulley.php
There is a calculator to help figure out what you need.
Old Dec 13, 2018 | 08:15 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
thank you, 3.90" comes the closest which that company has,thanks again
Old Dec 13, 2018 | 09:06 PM
aaronc7's Avatar
aaronc7
Are you sure the diameter is 8.5"? IW lists their 10 OD as 8.125" and 15 OD as 8.3xx". Either way 10% OD and 8.5" diameter does not compute, I would double check. I've seen A&A post a few times that general rule of thumb when you go to the IW balancer to run a s/c pulley that is 0.2" larger to compensate. 3.9 you may lose too much unless the pulley is indeed 8.5".
Old Dec 14, 2018 | 11:44 AM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
ok yes you might be right i measured outside to outside not down in from the grooves,I'll double check everything
Old Dec 14, 2018 | 12:19 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Ok i checked there website it is 8.125.thanks aaronc7
To SC Pulley Question
