Were did you guys drill through for your bottle brackets? I would like to put the bottle in the small storage compartment in the middle of the trunk, remember I have FRC.
Also did you guys run your main N20 line through the cabin or under the car?
I run two bottles, but I also have them in the storage compartment. If you want to mount it horizontally on the floor, then I suggest getting a piece of wood, carpeting it, drilling it for the brackets and then just wedging it in there. If you cut it correctly, it will never come out...and it WILL be extremely tight and safe in there. This way you're not drilling holes.
I had to b/c of the way I wanted mine set up.
I ran the nitrous line under the carpet, by the passenger door sill, and under the passenger floorboard to the grommet described above.
:nono: Wes doesnt know what he is talking about....... :D
