*NEW* Nitrous Oxide Injection Plate
Old Nov 2, 2002 | 09:20 AM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
Default *NEW* Nitrous Oxide Injection Plate (Photo)
We are pleased to announce the introduction of a new component for the LS1-LS6 engine platform that improves the per shot efficiency and power output of any nitrous oxide kit on the market today.
The "Power Plate" is a CNC machined, billet aluminum spacer plate that sandwiches between the throttle body and the intake manifold which is used to introduce nitrous oxide to the engine and absolutely no modifications to the O.E.M. air inlet ducting is necessary.
It can be integrated for use with any nitrous kit that is readily available on the aftermarket today which uses a single nitrous/fuel fogger nozzle for injection.
Complete product details and pictures can be found here:
http://www.dynotech-eng.com/power_plate.htm
The initial run of the first ten kits are in production now and will be available for outgoing shipment the week of Nov. 11th.
-DynoTech Engineering Inc.
[Modified by DynoTech Engineering, 1:48 AM 11/8/2002]
Old Nov 2, 2002 | 01:27 PM
AP's Avatar
AP
Default Re: *NEW* Nitrous Oxide Injection Plate (DynoTech Engineering)
:cool:
Old Nov 3, 2002 | 10:56 AM
NassBlue's Avatar
NassBlue
Nice product... looks to make a cleaner install :cheers:
TTT
Old Nov 3, 2002 | 12:55 PM
Dave00C5's Avatar
Dave00C5
Makes it a Nice, Clean install! :cheers: and your from Ft. Wayne :chevy
[Modified by Dave00C5, 11:34 AM 11/3/2002]
Old Nov 4, 2002 | 12:28 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: *NEW* Nitrous Oxide Injection Plate (Dave00C5)
Seems mighty close to the first intake runners. Any pics of the fogger in action to see the spray distribution pattern?
Old Nov 4, 2002 | 09:02 AM
DTE Powertrain
Collections Hold
Default Re: *NEW* Nitrous Oxide Injection Plate (C5-VERT)
No working pictures of the spray pattern at this time. The fogger nozzle used was a NX Express unit and the spray pattern will be one in the same as they specify for this type of injector nozzle.
The nearly equal exhaust port temperatures and the greater power output of the engine when our plate is used, (higher than the nitrous kit manufacturers claim) indicates a very homogenous, equal air/fuel/nitrous mixture in all 8 cylinders.
The system efficiency and power output per shot of nitrous is greatly increased due to the location of the injector nozzle in relation to the engine, therefore, a bottle of nitrous will have a longer effective life before refilling is needed.
Old Nov 7, 2002 | 09:49 PM
DTE Powertrain
Collections Hold
Photos now posted......
Old Nov 10, 2002 | 11:22 AM
corvette184's Avatar
corvette184
Default Re: *NEW* Nitrous Oxide Injection Plate (AP)
looks like just what i am looking for....but i am not to sure about moving the p/s pump around..... :yesnod:
Old Nov 11, 2002 | 08:28 AM
DTE Powertrain
Collections Hold
Default Re: *NEW* Nitrous Oxide Injection Plate (corvette184)
There is no moving of the P/S pump at all, but rather a slight relocation of the reservior to provide clearance for the throttle actuator motor.
Look closely, you cannot even detect a modification at all. That was engineered that way by design.
[Modified by DynoTech Engineering, 12:30 PM 11/11/2002]
Old Nov 11, 2002 | 09:44 PM
corvette184
i just emailed you......i want one....thanks :yesnod: :yesnod: :yesnod: i want to be bottle fed :cool:
Old Nov 22, 2002 | 03:07 PM
DTE Powertrain
Collections Hold
We now have completed kits in stock and ready for shipment as of last week. Complete product details can be seen at http://www.dynotech-eng.com
Average, regular 3 day ground shipping via UPS is $7 anywhere in the continental U.S.
To all those who have already purchased, thank you and enjoy!
Regards,
[Modified by DynoTech Engineering, 3:14 PM 11/22/2002]
Old Nov 23, 2002 | 10:07 PM
corvette184
got mine...looks very nice...quality is a1......nice hardware....should be nice.....it would be cool if it was anodized red :yesnod: :yesnod: :yesnod:
To *NEW* Nitrous Oxide Injection Plate
