Billet header flange with EGT bungs/threads
Time to introduce LSX 1.5” nominal billet flange with integrated EGT ports/bungs. First prototypes done! Upwards or downwards facing EGT bungs, 1/4 or 1/8NPT threads available depends options. Accepts 1/4 or 3/16 sensors.
Check out FB or IG killmode_corvette
Turpid porpoise (04-17-2019)
Thats is some gorgeous billety goodness, I'd love more info on that case.
Supporting Vendor
You could do O2's but would need to back them out some for the heat and contamination risk. If you're turbo, you'll also need some sort of back pressure compensation.
like to tap into my old cast iron ttix manifolds for the egts
it would be so cool to do custom manifolds with this as the base!
8 wb 02s here we come!!
