Main Spark Advance Table Feedback
Old Oct 18, 2019 | 10:58 PM
Water_Walker's Avatar
Water_Walker
Default Main Spark Advance Table Feedback
I am looking for comments or opinions (positive or negative) on what think about this table given the car.
02 z06
Stock Engine
Cam/headers/exhaust
Ti-trim/meth
Old Oct 19, 2019 | 11:43 AM
dragls's Avatar
dragls
I would drop the timing around peak torque area until it gets tuned.
Old Oct 19, 2019 | 08:36 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Seems real aggressive to me. I would be in the 15 degree range but that’s just me being conservative I guess.
Old Oct 19, 2019 | 09:41 PM
Kingtal0n's Avatar
Kingtal0n
never use the same number in two cells side by side. From left to right, the number is either increasing or decreasing. The timing is never 20.0000, its going to be 19.996, 20.005, 19.955, 19.970, 20.043, etc which can cause an oscillation in output (wavy torque line). digital electronics and the time between crank trigger events is an imprecise measurement. Although it is fairly exact, its far from perfect, there is some amount of prediction and mathematical uncertainty involved. Whereas the real life physical combustion engine has no such perturbations with operating frequency (the physical model doesn't randomly gain or lose energy as some form of error percentage the way a digital, mathematical model might be susceptible to because unlike digital computations the real world always follows conservation of matter and energy), Therefore It is always best to give the digital electronics a new target between trigger events so the error is lost in the shift from one cell to the next.
Old Oct 20, 2019 | 05:52 PM
Water_Walker
Unfortunately, this was a final tune out the door.
Old Oct 20, 2019 | 08:49 PM
Kingtal0n's Avatar
Kingtal0n
If you post the timing numbers we need to see the y-axis also because without that there is no reference.
IMHO It looks aggressive.
-usually engine timing is "all in" near 2400-2800rpm sometimes 3200 and I see upwards of 30* btdc as low as 1400rpm which makes me nervous
Old Oct 21, 2019 | 10:35 AM
Pekka_Perkeles's Avatar
Pekka_Perkeles
Originally Posted by dragls
I would drop the timing around peak torque area...
Agree.
Although cats may last longer than usually...
Old Oct 21, 2019 | 10:48 AM
Pekka_Perkeles
It's all between 0 and 1.20 grams.
2 degrees removed from the stock at upper load (from 22 to 20).
Old Oct 21, 2019 | 11:12 AM
TurboLX's Avatar
TurboLX
never use the same number in two cells side by side. From left to right, the number is either increasing or decreasing...
UGH, where to start?
There's NO PROBLEM having the same spark advance in two RPM cells next to each other. Where the heck do you get this stuff?
You have a lot more to learn about combustion. Combustion itself is somewhat stochastic. When we instrument engines for cylinder pressure on the development dynos at the OEM, we routinely see all kinds of variation in the signal even at steady state. We see so much that we actually look at the running average of the last 100 cycles on any given cylinder before displaying the pressure trace in CAS or Indicom. Even if we gave the engine the same locked spark advance (as confirmed with a scope), we would still see some variation in resulting cylinder pressure across cycles on the same cylinder. The short story is that combustion variation is easily 1-2% in perfect conditions, so being +/-0.1* spark is not a measurable change.
NOW, back to the OP...
The biggest issue I see in the table posted above is that the tuner flatlined the spark advance with respect to load at some point. Why would you not want spark to scale with engine load? If you actually took the time to optimize the spark table, you'd find that the engine wants some continuously decreasing spark as load increases. So either this one is way over-advanced up top (likely hidden from knock by the use of Meth/Octane), or it's way under-advanced in the moderate loads (a "safe" tune?) that will result in high EGTs if you aren't running full load. Even if the combo I'm calibrating doesn't use the full range of the spark table, I prefer to continue the trend I found for spark vs load out beyond the cells I saw on the dyno. This means that if the customer ever gets a higher load (low altitude, temperate drop, pulley change on a supercharger), then the ECU will at least make a directionally correct change to try and keep up with it.
Old Oct 21, 2019 | 03:55 PM
Kingtal0n's Avatar
Kingtal0n
lol tells me its ok to have the same number in more than one cell,
turns around and tells the op not to use the same number in more than one cell
i c wat u did there
I have fixed more than one wavy torque output oscillation by smoothing into gradually changing numbers and it is rare to see any robust factory timing map after 2002 which contains negative values along with any solid sections (unchanging) of numbers across multiple cells.
Old Oct 21, 2019 | 03:59 PM
Podium's Avatar
Podium
This is one of the dumbest things Ive read from you.
Old Oct 21, 2019 | 06:48 PM
Kingtal0n's Avatar
Kingtal0n
Come back after you've taken dynamic systems, dynamics, and completed advanced control courses for PHD
And then you might see a glimmer, or not, of truth to the statements I have made.
During engine modelling, the second derivative of angular velocity becomes negative in the time domain if following combustion event is identical with respect to fuel and timing.
That means the rate of engine acceleration is decreasing momentarily in the time domain given two identical ignition and fuel events coincide.
Old Oct 21, 2019 | 06:59 PM
glennd's Avatar
glennd
I agree with PODIUM
Old Oct 21, 2019 | 07:04 PM
Podium's Avatar
Podium
Are these online classes I can take?
Old Oct 21, 2019 | 07:20 PM
Kingtal0n's Avatar
Kingtal0n
lets forget that flat lining a timing advance table is mundane way to utilize effectiveness of computer control.
And say its okay just this once just to go against somebody on the internet
Old Oct 21, 2019 | 07:22 PM
Kingtal0n's Avatar
Kingtal0n
oh my god I just realized something. You all must have flat lined tables to behave this way. ROFL
Old Oct 21, 2019 | 07:29 PM
Podium's Avatar
Podium
Nobody said anything about "flat lining" a timing table.
You said this
Thats what we are talking about. Quit taking so many super smart classes so you can follow along.
To Main Spark Advance Table Feedback
Old Oct 21, 2019 | 07:42 PM
Podium's Avatar
Podium
STOCK c5z
STOCK G8
STOCK C6Z
2010 CTSV
You better call GM and let them know they dun messed up!
Old Oct 21, 2019 | 08:05 PM
Kingtal0n's Avatar
Kingtal0n
sigh noobs,
you have to increase the resolution of the table to see the true majestic beauty of a completely original GM timing table.
Behold, her true glory
An engine is a truly dynamical thing, where it is nearly impossible that two side by side cells would use the same exact timing number to the best use of the computer's control and engine's behavior.
so called "flat lines" or two identical cells only occur in places where the OEM engine was never run during the timing/behavior testing. i.e. around 6krpm the factory engine was not going much higher so it flat lines from 5600. The same is seen with pressure, naturally aspirated engines only go so far in airmass then it flatlines where the engine will never reach because "no data".
Old Oct 21, 2019 | 08:10 PM
Kingtal0n's Avatar
Kingtal0n
This is my main and only timing table for LS mild cam 5.3L, it works with 87 octane in the naturally aspirated region
you can laugh all you want but at the end of the day my torque lines are smooth sailing at zero smoothing and everyone else seems to have a problem with that one simple task.
