Nitrous install Questions ?????
Old Nov 15, 2002 | 02:19 AM
Malibu Vette's Avatar
Malibu Vette
Default Nitrous install Questions ?????
:confused:
I am finishing up my install and need to find where to get 2 switched 12 v sources for my setup. 1 is for the window switch so low current. the other is for the solenoid circuit so there is a little load. Where did you guys get the 12v source?
Old Nov 15, 2002 | 09:23 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Nitrous install Questions ????? (Malibu Vette)
got my switched off the radio.. Got my 12v off the battery (fuse box terminal)
Old Nov 15, 2002 | 08:23 PM
JohnGlenn's Avatar
JohnGlenn
You can get the switched 12V scource under the passenger side floor-toe board.
The following link is to the tech section of this forum, it will describe where the wires are.
https://www.corvetteforum.com/techti...=165&TopicID=1
Good Luck.
Old Nov 16, 2002 | 12:08 AM
so.txvette's Avatar
so.txvette
did my own install also..
just as above..
remove the floor pannel cover on the passengers side floor . look in the upper left corner ,their a plug cliped up there with a yellow, black,orange wire
(I believe the yellow is switched)
good luck
:smash:
Old Nov 16, 2002 | 08:52 PM
Malibu Vette
Default Re: Nitrous install Questions ????? (JohnGlenn)
Thanks John. It was exactly as you described. The forum members are great! :cheers:
To Nitrous install Questions ?????
