Im looking to purchase injectors to finish my build! Looking for a good set of matched 80's. I also will be changing my fuel rails down the road not sure which brand? But i want to make sure they will work together. I will be purchasing a boost manifold for my bov,bap,mechanical boost gauge, and alky kit. My question is which boost block to get with correct sizes? Thanks
Fuel rails take your pick... Holley, racetronix both look pretty nice.
Vacuum block, not sure what size barb fitting those all around, probably 1/8". So for a vacuum block with 1/8 NPT thread that should be perfect.
I'm running Deka 80s and they idle and work great all around. I'm actually kind of looking to upgrade to 1000cc or something around 100 lb/hr. If something comes up, maybe you'd be interested in mine?
I have the Deka 80's too and they work good enough but I think there are better options - only problem is they are much more expensive.
From my experience and research (Banish and Dsteck agree) Deka 80s are hard to control and tend to be highly variable at low pulse widths. Kinda like trying to put a nice precise nozzle on a fire hose vs a garden hose. Overall, for the money I would buy the Deka's again but my idle and part throttle trims are doing their job in closed loop keeping the fueling near stoich!! I have no issues at all once you get past the very low pulse widths.
Deka 60'seem to be much more tune-able if they flow enough for you. Not sure why...
Reason: typo
Yeah I've had no issues or gripes with Deka 80s. I have a mildish 226/230 cam that I've had for a while now.... my car runs better/smoother now with Deka 80 on SD tune than it ever did on much smaller injectors and with a MAF. I did have to tweak the injector data though to get it consistent and really good though.
Very interesting, I wish I lived in Florida as I would like to check out your ride. I have had SD in the back of my mind as a potential project but so far my "MAF and then fudge it" tune does everything I ask it to do. What smaller injectors were you running?
Reason: typo
Generally the Bosch injectors are "better". FIC, and then even a step up further would be ID. IMO the bigger the injectors start to get, the more important quality/good data is since you'll be idling with very small pulsewidths.
Most people seem to have no issues with Deka 80 though...and if they do it's probably something else, or bad injector data.
The best answer to what injectors you should run: ask your tuner. Tuners tend to find what they like best and it's best to stick to what they recommend. You'll have the least issues this way and it's one less variable into the equation, especially if it's an online tune where the tuner isn't physically there and troubleshooting can be tough.
80 lb/hr is equivalent to about 850cc if you're comparison shopping with FIC or ID. But IMO no need to be scared of Deka 80s.
Well, I live in New Mexico now, I'm sure you wouldn't wanna head out this way anyways! I should probably update that.
I think the biggest reason SD was better than MAF in my case was because of the cam. But the car really does recover from dips better, generally much smoother at low rpm/low load scenario with SD with my cam. That plus the fact I'm flowing over 67 lb/min made SD the obvious choice. Getting a great VE table is definitely a lot more work than dialing in the MAF as I'm sure you're well aware if you've done SD on your Fiero or whatever. I feel like my VE table is about 90 percent solution right now, I'd really like to get on the dyno for a couple hours and run open loop to quickly and efficiently get the last 10% polish done and get those hard to reach cells.
Past injectors I ran when NA.... Lucas 42lb/hr and GTP 36 or 39lb injectors. I originally had the lucas based on tuner recommendations, but then I started my own tuning and tried out the Bosch GTPs..... the GTPs were quite a bit better in low load/idle scenario. I read some stuff about the spray pattern was better suited for LS heads, but who knows. I guess the Deka is a "pencil" spray which also isn't supposed to be as good, but obviously it's working OK, even if not ideal.
This is a very good point - talk to you tuner and see what injectors he has worked with before and trusts the injectors and the data. This could save you a lot of headache and money and make for a happy tuner. Remember Happy tuner, happy life... Oh wait, that was happy wife, happy life.....
Thanks for the response. New Mexico is not so bad either - except in middle of summer I suppose!
check out fore fuel rails, I like those the best because they are a solid 1 piece design and can be bolted directly to the intake depending what length injectors you get... I used a cheap obx 6 port vacuum block and it works great... you can tee it into your brake booster hose to feed it and get whatever fittings you need for the block to hook up your bov, hobbs switch, etc
thanks neutron! Is there any issues running everything off the block? Fore is what i was looking at, i had there rails on my cobra nice stuff!
you can run everything you need to off the block, I believe the smaller ports are 1/8npt thread and mine came with a bunch of fittings and plugs but the barb end may not be the size you need so you can just get another 1/8npt fitting with the right barb end that you need and you're good
ok thanks, I will run the new tee from the brake booster to the mainfold mounting somewhere by the intercooler. Should i run the same size hose to the manifold that the brake booster is? Thanks
I have Deka 80 for around 10 years don't remember exactly but with no problems with the data they provided . I run e85 in the summer and change my tune to push over 1000rwp in the summer then i change back to regular fuel in the winter to get better gas mileage and take a bunch of power out. I have ls2 fuel rails. Just wonder why you don't run them. Before you ask how i can run that much power on 80's i have two meth pumps with 4 15gph nozzles.I know something happens to the pumps boom but i hope my tune that put in for safety will save the engine.
I looked at fic's flow chart 72, 650cc! It seems it would be perfect and would give me room for more power..i will also be running 100% meth i know that will help with the injectors.
