A&A pulley alignment problem.
Old Jan 31, 2020 | 10:58 PM
4door5g's Avatar
4door5g
Default A&A pulley alignment problem.
I recently picked up a c5z with a a&a kit and the belt is one rib off of the fixed ribbed pulley. Everything else appears to be in line. I seen a few post from around 06-08 that they replaced the bracket and that fixed the problem. But is there anything else I can check before I just plan on replacing a bracket? It literally looks like if I put a washer behind the pulley (pushing it closer to the motor) it line right up and be fine. Thanks for any info and help
Old Jan 31, 2020 | 11:58 PM
silver408z's Avatar
silver408z
I have read about some of the kits, either ecs, a&a or maybe both, need a washer to line it up. Seems like I saw it even came in the kit or something. I did not install my kit so I don't have any hands on experience.
Old Feb 1, 2020 | 12:12 AM
StingrayRebel's Avatar
StingrayRebel
is the blower pulley hub the same on both sides?... sometimes you can flip them around and fix it but if they are the same then a spacer could do it... have you checked the alignment of the other pulleys with a laser?
Old Feb 1, 2020 | 11:21 AM
4door5g's Avatar
4door5g
Well dug into it alittle more and looks like the bracket its self is actually twisted.
Old Feb 1, 2020 | 09:15 PM
helga203's Avatar
helga203
Can you get any pictures??
Old Feb 1, 2020 | 09:39 PM
StingrayRebel
I highly doubt the bracket is physically twisted, maybe the spacers weren't installed in the right spot... post pics if you can
Old Feb 1, 2020 | 10:22 PM
4door5g's Avatar
4door5g
I'll try to post some pics tomorrow. I had to put some washers to shim out one part of the bracket and get it twisted some what back to form. Probably not the best way but better then 800-1000 for a new bracket.
Old Feb 20, 2021 | 09:20 PM
Deven Davidoff's Avatar
Deven Davidoff
Same issue. Just got mine installed and it’s out a bit. Can’t tell if it’s the supercharger pulley or the fixed ribbed pulley.
Old Mar 11, 2021 | 12:30 PM
Deven Davidoff
Water pump causing miss alignment. Switched from Gates to AC Delco. Problem solved.
To A&A pulley alignment problem.
