Secondary Fuel Pump Location
Old Dec 2, 2020 | 09:34 PM
NJShoreRR's Avatar
NJShoreRR
Default Secondary Fuel Pump Location
I am doing some updates this winter to support my new motor/blower setup. I am adding a secondary fuel system that will be activated by a hobbs switch. I've seen some people mount the pump in next to the torque tube. I was doing some cleaning while the motor is out and I saw this spot behind the drivers side fender and thought that looked like a good spot for it. I was thinking that maybe having the pump so far from the tank would be an issue?
Any input would be greatly appreciated!
Old Dec 2, 2020 | 10:31 PM
TimbrSS's Avatar
TimbrSS
Pump will push better than pull. Plenty of room in front of rear tire. Save the room up front for filters n regulators.
Old Dec 2, 2020 | 10:37 PM
NJShoreRR's Avatar
NJShoreRR
Great setup!
Do you have any pics from further away that shows a little better you mounted the pump and ran the lines from the tank?
Old Dec 2, 2020 | 10:45 PM
TimbrSS's Avatar
TimbrSS
Ecs fuel ring.
Old Dec 4, 2020 | 08:30 PM
nfantbabyjesus's Avatar
nfantbabyjesus
Mine is mounted in front of the rear tire as well.
Old Dec 4, 2020 | 08:38 PM
NJShoreRR's Avatar
NJShoreRR
I stopped at ECS today and picked up a fuel block. Your setups look so much neater with them.
To Secondary Fuel Pump Location
