Cut down radiator identification help
After measuring everything to make sure it wasn't an obvious no-go, it dropped right in with little fuss (pulling the stock piece was a different story). As a pleasant surprise, even though it's a true 3" thick, it fit like a glove and I didn't appear to lose any space between the fans and motor. Not only was I able to remove the 1" drop spacers on the cradle, but I do believe there is room for a 4" intake pipe (although I'll leave the dongle for now).
I was under the impression when I bought it, that it was an RSD radiator. But after looking at the RSD pics again, and looking at the construction of Ron Davis radiators, I'm fairly certain this is actually a cut down Ron Davis radiator. Odd part is, I'm finding almost no info on such a thing. I've seen a possible mention or two of it, but no pictures, other members that have run it, and it's not on Ron Davis' site. Can anyone confirm that Ron Davis ever made a cut down version?
I've searched the part numbers on it and got nada. It's also got what looks like an order number and name scribed on the bottom with a Nov 2017 date.
This is with no spacers in the cradle. A 4" intake tube might be a tight fit, but if that ever becomes a reality, spacers will make that easy. I'm going to enjoy the additional ground clearance for now, which was my main objective
