How much Boost
Old Dec 29, 2021 | 12:39 PM
SmoothFRC's Avatar
SmoothFRC
Originally Posted by ltnate
I didn't get the Dyno but he said it was making 642 on stock fuel system. Of course I haven't seen the tune.
Stock fuel system you say…. Upgrade the fuel system while getting the block fixed.
Old Dec 29, 2021 | 05:15 PM
FourG63 97GST's Avatar
FourG63 97GST
wait, stock as in stock fuel pump and injectors? no meth? did they do the blower, cam install also?
To make several tuning adjustments, they should of caught that the car is running out of fuel, way before making it all the way to redline and 642whp, there's just back to back to back red flags here. I wouldn't trust them to remedy this, they aren't capable. "reputable" is being used loosely here. sorry you had to go through this. but that car needs to go elsewhere, chalk it up as a life lesson. the "fast, cheap, reliable" logic will always apply in this game.
Old Jan 5, 2022 | 08:39 AM
Rkreigh's Avatar
Rkreigh
so I can help with the "good, fast, and cheap" mission. See my add in the c5 section for either an ls6 block or a fully built iron 4.8 short block
the 2003 and later blocks have a bit thicker sleeve and hold up to boost. Have all the parts to build it out
Or I have a complete 4.8 junk yard warrior with stock std crank, gen4 rods with fresh bolts, and wiseco 10-1 forged pistons
the 4.8 little thumper is ready to go. Let me know if interested.
Old Jan 7, 2022 | 01:47 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Definitely don't sleeve that block. Look at the pic of the cracked sleeve. The water jacket wall is also cracked. No dice, homie. Time to grab a 4.8 or 5.3, gap those rings, upgrade the fuel and get back at it for cheap.
Shame about the engine. Stuff happens though.
Old Jan 10, 2022 | 06:23 PM
ltnate's Avatar
ltnate
Is the Ls6 Block still available?
Old Apr 22, 2022 | 04:44 PM
ltnate's Avatar
ltnate
Default Almost ready for the road
It's been a long journey but almost there now.
