Higher Milage Boosting
Old Mar 31, 2022 | 05:39 PM
vyper202's Avatar
vyper202
Default Higher Milage Boosting
Looking for opinions from real world users.... I have an 01 M6 with 149K on it, one owner before me, older gentleman bought it new. Its 100% stock except for a Ti exhaust. I wasn't interested in changing to headers, x pipe, hi flow cats, blah blah.... but I have been thinking of adding a supercharger after driving my friends that has an ECS supercharger.
Would the higher miles on a stock 5.7 be of great concern when thinking of adding a supercharger? I don't want radical, maybe 5PSI to get a bit more GRRRR out of the old girl..... Thanks guys!
Old Apr 1, 2022 | 02:19 AM
C6-LS2-MN6's Avatar
C6-LS2-MN6
If budget and reliability are your two main concerns on an older inexpensive car.... I would definitely consider doing:
-Long Tube headers / no cats
-4.10 gears
-Dyno tune
You will be amazed at the difference! Remember, even the cheapest and smallest C5 supercharger kits will get you over 500rwhp real quick! Now your next problem will be the weak factory clutch in the 149K LS1 C5 that will start to slip! That will be a VERY expensive repair bill not anticipated.
Old Apr 1, 2022 | 07:41 AM
Rkreigh's Avatar
Rkreigh
if the engine has good compression and better still does a good leak down test I wouldn't hesitate
the blower will pick up the torq much more than the head cam and make for a nicer driving car
Old Apr 4, 2022 | 12:06 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
As Rkreigh said - if the engine is still happy, get the blower and don't look back.
My opinion remains that every C5 should have come off the factory line with 10psi of boost. They're just fun cars at that point.
Old Apr 5, 2022 | 04:02 PM
imma_stocker's Avatar
imma_stocker
Higher mileage just means more ring gap. Extra ring gap is good for boost. *assuming healthy compression, leak down, and bearings.
As C6 mentioned, the driveline will need attention and $$.
Old Apr 5, 2022 | 04:52 PM
Tusc's Avatar
Tusc
Hmmm...
Trans mount, diff brace, RST clutch, springs and trunions, maybe lifters to be extra.
Also extra... Hub, oil pump, good chain.
Old Apr 7, 2022 | 07:07 PM
vyper202's Avatar
vyper202
Sounds like I'm going to keep this one stock.... may be getting into a C6 and can start the upgrades on that platform....
Old Apr 7, 2022 | 07:29 PM
Tusc's Avatar
Tusc
Same stuff, different body, higher cost. Good platform of course. Make it hap'n and have fun!
To Higher Milage Boosting
