Methanol Debate
Old Apr 4, 2022 | 01:06 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default Methanol Debate
I'll be breaking in the 402 combo later this spring.
I think of it as a moderate build, not an extreme one. Cathedral heads, mid-range cam a bit small for the displacement, oem LS2 block, etc. Haltech elite ecu, V3-Ti, 10.55:1, prc 225, jam cam, forged internals, expecting roughly 14psi on a 3.6 pulley. The splurge points were the ecu, ccw crank, and crower shaft rockers. C5-LS2-MN6 made 760 / 630 on a loosely comparable build.
I ran one of Julio's alkycontrol kits with a small shot on my 99 when it was making 10psi and about 500rw on an untouched LS1.
But what is the benefit at this power level if I have larger injectors and steady fuel system with dual pumps? Just running dual nozzles to run more timing? What's the risk here with the spray not being equal to each cylinder and running #7 (typically) hotter even if its forged?
Old Apr 4, 2022 | 07:48 AM
Rkreigh's Avatar
Rkreigh
julio makes a great kit. I'd sure consider direct port alchy or if the budget allows go straight to e85
alchy is the boost juice but at higher flows the factory intake doesn't do very well keeping the cyl distribution equal as you mention
those intakes are designed for "dry flow" and with all the bends and turns the alchy tends to wet the intake wall and puddle up causing cyl to cyl variance
on a big f1 blower car he had the Haltech 8 channel EGTs and we noticed big cyl temp variance on the egts that shows alchy was carrying back and puddling in the rear of the intake making the normally lean #7 go way rich
he went direct port alchy and picked up both hp (40) on the same alcy flow and the egts were MUCH more even and the engine ran smoother
Old Apr 4, 2022 | 10:04 AM
Tusc's Avatar
Tusc
I'm set up for E85 on my return style setup when done. Like the methanol, I'll have to import it from VP fuels since local pumps are over an hour away in either direction. This is a street car by far so the frequency of ethanol use would be low. If I still ran the methanol kit, I would see about setting the haltech run it instead of a map sensor and rheostat dial.
The intake is Fast 92 which I'm keeping for this season since I was just let go two months befkre the wedding. Don't call your boss on Sunday seeking support and say you've got chest pain from the stress. They came in first thing Monday and sent me packing. Keeping the bills reasonable for now.
Old Apr 4, 2022 | 03:39 PM
Rkreigh's Avatar
Rkreigh
I wanted to get "fancy" and run haltech with flex fuel and also an alchy injection kit since I already have it on the car
I got an amp driver box so the haltech can control the alchy kit and add the boost juice when no e85 is available.
I hope to find a really competent haltech installer to make this a reality I have the 8 channel egt kit too
Old Apr 4, 2022 | 07:52 PM
C6-LS2-MN6's Avatar
C6-LS2-MN6
I was also going to do a Holley Terminator X computer in my C5, but there was no way to program the car to pass yearly state vehicle emissions testing without all the parameters of the factory ecu. I talked to one shop that "attempted" the piggy back ecu trick to run two ecu's in order to pass OB2 testing, but they said it was a VERY difficult and a costly task that would even challenge NASA! Even after all the R&D there were still a few issues making the two communicate and they will never do it again. To make a long story short...you would need to install double(2X) various engine sensors to run separate computers since some sensor signals can not be spliced into. A real pain. I chose to pass on the holley terminator X due to car resale value of the next potential owner not being able to buy it and get it to pass a state inspection. I've sold a lot of modified cars....and that's the first concern of future buyers. I thought CT was an emission state too?
If you live in a non emission state or its a strait up track car.... I guess it would be a viable option.
Old Apr 4, 2022 | 07:57 PM
Rkreigh's Avatar
Rkreigh
the haltech folks claim the obd2 plug in test remains intact as well as the stock gauges.
That was my main requirement. I thought the Holley high end systems can do that as well.
The 04 vette ecm can run flex fuel too. Not nearly as well as an aftermarket system. But well enough that you could get home off big boost if you run out of e85
I'm interested in looking into that as I can use the haltech on some other goofy project like my kit car where I want to run the LS engine in something half the weight of the vette
Old Apr 5, 2022 | 12:38 AM
Tusc's Avatar
Tusc
Correct. By reading and by reference from Bret the Haltech is supoosed to have the capability to piggyback. I'll do my best to make it easily reversible too though wiring is not my forte.
I had read into various threads on flex fuel capacity for the C5, which ecus were compatible for swap into our older cars and which could be unlocked/reprogrammed. My interest was in doing that for my daily 99 except that the promised advent of E85 pumps locally all disappeared. I did still invest in a bluetooth obd2 adapter which can can program ecus and makenuse of ooen source software to do so. I considered it a small investment in future swaps 20 years from now and it cost less than a single license.
Long way to go before testing the methanol. Still debatable. That 8 channel egt sounds trick. Ive heard it becomes a case of the more you know, the more you don't want to know.
Old Apr 9, 2022 | 10:23 AM
helga203's Avatar
helga203
I reason to run meth with addiction to gain some hp and it cools the engine chamber down considerably to help with detention and not breaking a piston. Then on the other hand if u run flex u do not need meth flex alone cools the chamber down more than meth. Then if u use race fuel u dont need meth meth, again those fuels cool the chanber down to literally iat is not relevant. Buddy n/a running e85 with 16 to 1 compression e85 loves compression Im meth doesn't turn on until 10lbs even with 2 15 nozzles with my f2 30lbs boost i was still seeing 250 to 270 iat. Im running f1-x when i was running 30lbs i saw low 2oo to 220 for the pass 30k mile and i have to get my fix of hp daily, so this is every day. I go through 5gls of meth a week. And by the way i tune myself. JMI
Old Apr 16, 2022 | 11:11 AM
CorvetteBrent's Avatar
CorvetteBrent
At last, a new 76 gas station selling E85 has opened in my city, so folks don't have to drive all the way to Sarasota (45 minutes north) or Ft. Myers (an hour south) to purchase. Maybe none of my business, just curious, what type or category of job did you have which produced lots of stress? It seems unfair that you would be "sent packing" for being frank about a stress/health issue (and impractical, considering the current labor shortage). Sorry this happened to you, but, hopefully, it will be a blessing leading to a better opportunity.Ultimately, that company will "reap what it sows".
Old Apr 16, 2022 | 12:54 PM
Tusc's Avatar
Tusc
I run nursing homes. There are no staff to be had and endless emergencies. Those staff who remain are either thr good ones who are beyond burned out or the ones no one would hire in normal world.
To Methanol Debate
