Is this enough fuel pump on E85?
Old May 15, 2022 | 01:22 PM
Darbs's Avatar
Darbs
Default Is this enough fuel pump on E85?
Will a stock 04 z06 fuel pump with a secondary aem380 on a hobs switch (Ecs stage 1 fuel system) support 750whp on E85?
If not, would it if I added a BAP to the factory pump?
Old May 15, 2022 | 10:34 PM
_zebra's Avatar
_zebra
not sure, but for reference: my Kenne Bell BaP+stock 2000 pump wasn't enough to feed Siemens 60s on 93 for just under 700whp.
currently running a Walbro 450, return conversion, & aftermarket regulator on the same injectors. if i'd went e85, my injectors wouldn't be enough, but the pump sure would've (was making mid 70s line pressure on the stock returnless regulator)
