Changed my meth usage.
Old Jul 18, 2022 | 11:27 AM
ChipBell's Avatar
ChipBell
Default Changed my meth usage.
Sounds funny. But I did. I was using washer fluid but it worries me when I find a couple little drops in my throttle body. Plus I think that it has a weird texture to it that may leave something somewhere. Polyethylene glycol maybe?
So I stopped using that and now I use 50% heat and 50% distilled water. Is that ok? And with that do I need to adjust when the injection starts or the volume of it?
Just wondering.
Old Jul 21, 2022 | 11:59 AM
Cohiba's Avatar
Cohiba
I don't have a car that runs meth, but I am considering it down the road. I planned on running -20° wiper fluid and have not heard any issues from it. My concern with meth has always been somehow loosing control of the spray volume and hydro locking a engine. Electronics control the systems and electronics are great when they work. I would think drops in throttle body will occur regardless of what you spray at some time or another.
Old Jul 25, 2022 | 02:22 PM
brentsz06's Avatar
brentsz06
When I had my viper everyone used -32* washer fluid as it had a near 50/50 mix. I too ran it. Only complaint was the color would stain the inside of engine parts. But it didn't effect anything.
Old Aug 24, 2022 | 11:44 AM
TimbrSS's Avatar
TimbrSS
You can buy Snow Boost Juice on Amazon for $50 for 4 gallons. It's 50/50 mix. Yes, kind of expensive for what it is, but you know what you are getting and can just pour it in and go.
Old Aug 24, 2022 | 11:49 AM
TimbrSS's Avatar
TimbrSS
The more common failure is the system not coming on at all. Pump needs rebuilt at least every other year. Need to tune in a lot of timing retard at higher IAT to protect against meth failure, and don't rely on it to keep AFR rich enough to not scatter your block.
Old Aug 24, 2022 | 01:35 PM
heggsc5's Avatar
heggsc5
That's pretty much what's kept me away from it. Too much extra crap to worry about lol
Old Aug 24, 2022 | 01:41 PM
SmoothFRC's Avatar
SmoothFRC
Once it's tuned for it, it's set it and forget it (Aside from ensuring you actually have some in the tank).
The whole pump rebuild thing only applies if you are running 100% meth - If you run 50/50, I do not believe you have this issue... So depends on what you want.
Old Aug 24, 2022 | 02:04 PM
heggsc5's Avatar
heggsc5
I get it, but it's just one more point of failure that could be catastrophic and more stuff to remember to check on/fill/etc. The potential for rebuild is just a secondary consideration really, but definitely a consideration. Personal preference, I just like to keep things as simple as possible. I'd much rather go e85, but there's added considerations there as well haha.
Old Aug 24, 2022 | 05:14 PM
vettefx76's Avatar
vettefx76
I've read of several guys doing E85 AND water-meth Some say its a benefit some say no, idk...
Old Aug 24, 2022 | 06:17 PM
SmoothFRC's Avatar
SmoothFRC
if it’s tuned for it, what’s going to break? It will pull timing and keep you safe once iat’s go up.
Old Sep 2, 2022 | 01:33 AM
brentsz06's Avatar
brentsz06
I ran meth as a safety net. Never tuned the car to use meth to make more power. Tune the car without it and then add it. You'll still pick up a bit of power but the main advantage is added safety. This way, if there's a meth failure, the cars never in danger.
Old Sep 6, 2022 | 05:49 PM
heggsc5's Avatar
heggsc5
I'm no expert in the matter and I'm sure you have more experience than myself, so I'm not trying to argue with you lol. I just feel like it's an unnecessary risk with added complexity. If anything, I'd be much more inclined to do as the fella above mentioned just for safety. Especially since I'm limited to 91 octane with high summer temps.
Old Sep 6, 2022 | 06:17 PM
vettefx76's Avatar
vettefx76
A tuner told me that the red dye in Boost juice causes problems with clogging the sprayer nozzle... Idk... anyone have issues??
To Changed my meth usage.
