Fuel Pump
Old Jan 27, 2003 | 01:19 PM
urslooow's Avatar
urslooow
Default Fuel Pump
With a SC C5 (see sig below) when is it necessary to add a fuel pump? Is it beneficial tom add one to the ati setup (7lb boost-38lbs/hr injectors)?
Old Jan 27, 2003 | 01:28 PM
Z06 Mike's Avatar
Z06 Mike
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Fuel Pump (urslooow)
Are you getting detonation? What were your A/F ratios on the wide-band dyno?? What is your fuel pressure at WOT?
Old Jan 27, 2003 | 01:29 PM
urslooow's Avatar
urslooow
Default Re: Fuel Pump (OCMike)
car runs perfectly. No detonation, A/F done by breathless, I"m just wondering if a fuel pump will enhance performance
Old Jan 27, 2003 | 05:26 PM
Z06 Mike's Avatar
Z06 Mike
The fuel pump upgrade is more of a prevention thing as opposed to performance. I think as a general rule, if you are making 500rwhp or less AND have the proper injectors AND competent tuning, you should be fine. For peace-of-mind, I would add a Racetronix (Walbro) or similar fuel pump setup.
Old Jan 27, 2003 | 06:06 PM
KEPRGHT's Avatar
KEPRGHT
urslooow
nope, no performance gain.
you want adiquate fuel to make sure you dont blow your motor. no other reason. Tuning is what improves performance. Its all about your Air / Fuel ratio witch makes exhaust gas temps high or low depending on rich or lean fuel conditions. Getting the perfect balance at all RPMs while maintaining 0 knock/ping is what you want to make max power.
To Fuel Pump
